Question about Kenmore Washing Machines
I have a Kenmore Washer that stops in the middle of the washing cycle. The water doesn't drain or anything. I have to take all of the clothes out and scoop out 90% of the water and than turn the washer to spin to get out the remaining water. Also, when the machine shuts off it won't do anything if I move the dial and turn it to rinse or spin until I remove the water that is in the machine.
My washing machine stop drain after first cycle of wash. machine only works on wash cycles
Posted on Sep 12, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the belt and lid switch or a broken lid switch plunger. Also check the lid switch actuator and the timer. Please replace whichever is required to be replaced.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 11, 2009
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
I HAVE A KENMORE WASHER THAT I BOUGHT BRAND NEW IN 2002. AFTER IT FINISHES ITS INITIAL WASH, IT DOESN'T DRAIN LIKE IT SUPPOSE TO, AND CONTINUES THROUGH THE REST OF THE (ENTIRE)CYCLE, UNTIL IT REACHES...
Change the main controll, the one behind the dial that you turn. About 75.00. bucks. Clean hose from lint build up at pump exit inside washer.
May 12, 2009 | Washing Machines
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer won't drain.
Sounds like the pump is clogged or stripped out. It's mounted on the front of the motor in the middle of the bottom. There's only 2 clips and hoses that hold it on. These are known for stripping out in the middle. They are just plastic, but fairly easy to fix.
Mar 14, 2009 | Kenmore 24032\24036 Top Load Washer
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Model 24642300
It is usually a coupler, look under to see if black shavings
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Washer problem
Inspect the drain hose, see if there is any obstruction.
Try to understand if the machine does not drain at all or if the cycle is not completing , and timer stops before completinc cycle.
If the machine is not draining, then, once you check the drain hose and see no obstruction in there, it can be a faulty drain pump, or a faulty water level switch. If machine instead does not complete the cycle, it is a faulty timer/programmer.
See here for more detailed explanation: It won't drain
Sep 08, 2008 | Kenmore 22422 Top Load Washer
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
100 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
