Question about Dell Inspiron 6000 Notebook
When the lap top logs off front light stays on
    President:
  • 2,600 Answers
Do you still have the power cord plugged in? There are indicator light s for Battery operation, power on, hard drive activity. If you just logged off but the laptop is stillpowered on, then there will be a light indicating that. If you powered off the laptop but left it plugged into a wall outlet, then there is a chrging indicator that will stay lit.
Posted on Sep 11, 2009
Why is my screen black on a Dell inspiron?
if you do not even see the bios bootup screen then likeley either the light pack or the video card on the laptop is dead
Aug 30, 2014 | Dell Inspiron Computers & Internet
Facebook help page
Hello
Is it show your profile page on your own laptop ?
do your laptop open other webpage ?
Apr 05, 2014 | Computers & Internet
Abs on vr commodore light stays on solutions
Error logs are a great thing. They will help you find intermittent problems and start you off in a general direction of where a problem could be. There is a great level of detail on the justcommodores site on checking error codes logged by the engine management system, but this does not detail anything about the abs system. The abs warning light is not as common as the check engine warning light. Reading through the posts, I haven't found any detail on checking error codes logged by the abs system.
So here it is. For those of you familiar with checking the engine error codes, this procedure is so simple its not funny.
Basically, to check the engine error log, you bridge the 5th (ground) and 6th pins in the ODB connector under the steering wheel.
To check the ABS error log, using the same trusty calibrated paper clip, you simply bridge pins 5 and 12 of the connector.
To find pins 5 and 12, start at the top left hand corner. That is pin one. Going to the right, you count pin 2,3,4 etc. Once you get to the end, jump back to the start of the bottom left level of pins and keep counting. Pin 5 is about halfway along the top row, pin 12 is a little left of the middle in the bottom row.
Reading the error codes is the same procedure (counting the flashes), except now, the ABS light flashes (as opposed to the engine light when checking the engine codes).
The ABS log also uses code 12 firstly, with any errors logged shown after that. If no errors are logged, the 12 will flash again.
Error codes for the ABS error log (VR/VS) are as follows:
12 Diagnostic system operational
21 Right hand front wheel speed sensor fault
23 Right hand front wheel speed sensor continuity fault
25 Left hand front wheel speed sensor fault
27 Left hand front wheel speed sensor continuity fault
28 Wheel speed sensor frequency error
31 Right hand rear wheel speed sensor fault
33 Right hand rear wheel speed sensor continuity fault
35 Left hand rear wheel speed sensor fault
37 Left hand rear wheel speed sensor continuity fault
41 Right hand front inlet solenoid valve circuit fault
42 Right hand front outlet solenoid valve circuit fault
45 Left hand front inlet solenoid valve circuit fault
46 Left hand front outlet solenoid valve circuit fault
55 Rear inlet solenoid valve circuit fault
56 Rear outlet solenoid valve circuit fault
61 Pump motor relay circuit fault
63 Valve relay circuit fault
71 ABS control module internal fault
The above guide has been verified on a VR/VS. Checking the error log on all models prior to VR/VS is the same for the engine log, and I would assume that the same can be said for the ABS log, would be happy if someone could verify this for me.
Sep 21, 2013 | 2005 Mazda Tribute
Deleled a add- on ( I Think ) to my lap top , that let me log on to my wireless net work. My lap top wont let me log on to myt wireless net. Do I just need to restall my disk that came with the wirless...
have you tried reseting the network settings. it should reset passwords and other settings back to orginal factory settings or the disk might just do the same
Sep 05, 2011 | Averatec 3200 Notebook
When i log into yahoo i am not able to ready my emails and it screen goes blank . only happens on my lap top computer
When i log into yahoo Problem with the Yahoo Mail when i log into yahoo i am not able to ready my emails and it screen goes blank . only happens on my lap top computer
Feb 26, 2011 | Yahoo Mail
Lap top stays in standby mode Model Compaq
check whether the charger adaptor its connect properly. Then press down the shut down button, dont release it on till the indicator light for standy is off. You press the button again to on it.
Nov 21, 2009 | Computers & Internet
The 4th light on the left hand side is on and i dont know what this means, car did not come with the manual so i really need to find out what this means.
Forth light on left, counting from bottom is the seat belt light-should look like a stick person facing forward with belt across them. If it is the forth light on left, counting from top it is the front air bag light-looks like a stick person facing sideways with a solid circle/ball above their lap. My airbag light, in my 2002, stays on for months and then will go off for months, then comes back on again. Has been doing this since it was quite new.
Sep 27, 2009 | 2002 Ford Escape
Grand-ma knows best
It won't switch on at all, the power light is on at the front and the battery light shows re-charging. But when I press the power button on top nothing happens
Nov 22, 2008 | Toshiba Satellite M35X-S111 Notebook
Intermittant breakdown of connection
Try going to the usb and the wireless adapter in device manager, properties. And make sure that the computer does not shut them off to save power.
Please let me know how you make out.
Mar 01, 2008 | Acer Aspire 3690-2196 Notebook
Dell Inspiron 6000 Notebook Logo
112 people viewed this question
Alun Cox
