Question about Cell Phones
My phonw wont work
I have a motorola w490 and the buttons wont work how do i fix it?
Need Driver for W490
You can find drivers on our support page.
Motorola Support Find Answers Motorola Mobility Inc
Mark
Motorola Support
Apr 09, 2014 | Motorola Mobility W490 Cellular Phone
I'm getting a boot loader error, "ph sig err 35:02:" How do I fix this?
your phone is stuck in bootloader mode and needs to be reflashed if your still under warranty then try and just return it for a new one. If not then you"ll have to download a backup of either a w490 or w510. Both are free.
w490 here:http://www.opera.com/mobile/download/motorola/w490/
w510 here:http://www.opera.com/mobile/download/motorola/w510/
May 08, 2011 | Motorola Mobility W490 Cellular Phone
Can't reset phone as no buttons work. I get calls
You can get it repaired but i think it'll cost the same price you brought the phone bacuse thats what happened to my phone when i wrecked just the screen so you might aswell buy a new phone but thats only if its the same price so goodluck :) and please rate this solution...
Jun 06, 2010 | Motorola Mobility W490 Cellular Phone
Motorola w490 reads my memory card for like a second then it wont then it reads it again
just try to format ur memory card with ur pc by using this tool:
http://en.kioskea.net/remote/download_get.php?ID=127
and remember to select FAT otherwise ur card wont be detected by ur phone,if it doesnt work then do the same thing by selecting FAT32.
Another reason might be ur card slot is loose try to rise the pins up but be cautious not to damage the pins
if it wont work then u hv a problem with ur mobile hardware so contact technician.
Mar 29, 2010 | Motorola Mobility W490 Cellular Phone
Motorola W490 wont charge
i suggest you test your phone charger with another similar phone and see if it will charge.
If it does, it means the charger is still very much ok. The problem could be from the charging port. Change the charging and see if it will charge.
Best regards.
Feb 07, 2010 | Motorola Mobility W490 Cellular Phone
The keypad do not work
Either a software re flash may help or a keypad replacement. Usually facial moisture could be a cause of this. i would recommend trying a blow dryer on the keypad for 40 seconds with out the battery to see if that fixes the problem
Apr 06, 2009 | Motorola Mobility W490 Cellular Phone
Cell Phones Logo
63 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
