Question about EliteGroup ECS A535 Notebook
LCD Screen dims out regularly
I've had this laptop for a couple of years and am quite fond of it - even though I have a newer much-more powerful laptop. It started having an issue with the LCD screen a couple of months ago where it would dim out right after booting up. Sometimes, if I reboot or simply log out and log back on, it would restore video for a short period of time and dim out again. After doing a significant amount of research, I came to the conclusion that perhaps the LCD inverter has gone bad. Is this a reasonable conclusion? Looking for this part is quite a chore, and have been told by a number of places that the laptop is too old and the part is no longer available. I also learned that there are two OEM replacement manufacturers of the LCD screen itself - one by Quanta (part # QD141X1LH03) and another by Chei Mei (part # N141XB-L03) - but these parts exceed what I think is reasonable to repair this oldster and I'm waffling on going for it or simply removing the new HD I popped in this thing a year ago and tossing the laptop.
Any opinions or suggestions - please reply within a few days as I will make a decision one way or another soon...
Thanks!
    Sergeant:
  • 324 Answers
You might want to do a quick check on ebay and see if anyone has something for sale there that you could use. Also, you might want to check to make sure that the LCD cables are firmly seated in their connectors. Reseating them may sometimes help with a problem like this. Also, the lid switch may be loose, broken or going bad. The next time you loose the display, you might try manually operating that switch, just to see what happens.
Ron-
Posted on Dec 10, 2007
Hdmi on insignia lcd 37 not working
just upgrade, really not worth fixing. sounds like board is bad
Aug 01, 2012 | Insignia NS-LCD37 37 in. LCD TV
I shut my computer down, I then traveled about 10 minutes in a car. When I arrived the computer had not been dropped and nothing hit it. When I attempted to turn it on it booted all the way. I could hear...
It is for sure that a damage is done on the LCD and it needs to be checked on HOW THIS HAD HAPPENED.
It seems that if the laptop was not shut but the LCD display door was made to stay OPEN while you were driving then the motion/vibration could have damaged the LCD or the linking wires to the LCD panel. Check carefully on the hinges of the laptop and see if there is any cracks. Also if there is display on an external monitor then the PC is working fine . You can open the laptop and ccheck if any connector of the LCD panel is loose. If no the LCD is a suspect and You must take an opinion from HP. Claim for warranty if the time limit is within.
Jul 13, 2011 | HP Pavilion dv4-1140go Laptop
Hello, I have a Compaq CQ60 and have problems with the LCD display, which works intermittently. I had the entire LCD replaced about 4.5 months ago. Worked great until a couple weeks ago, the LCD went...
is this a CCFL LDC
if yes the inverter is bad. (a card tiny, and thin)
its old LT.
the books are gone now.
the service book tells you how to replace the CCFL inverter
find a used good one is problematc.
why not buy a newer LT
or just run the external screen and be happy
I guess you have not read the user guide yet?
about the VGA hot key.
mine has.:
1: external only
2: internal only
3 both
4: auto. (i think only my newer HP has this)
mine is Fn+f4, but on a relic compaq, gee buy the book,
or google search for it for weeks,
next time post to HP< there is no COMPAQ for years.
hp owns it. totally
ever seen this before. the fail like LT batteries do. often.
http://www.ebay.com/itm/New-15-6-Laptop-Screen-LCD-Inverter-for-Hp-Compaq-G60-G50-CQ50-CQ60-Series-/251312052451?hash=item3a835d98e3:g:ARYAAOSwal5YJoxR
search there "compaq CQ60 inverter"
bingo.
when the sceen is dead do this.
see the flash light here, BINGO? bingo for inverter *****?
http://pcdied.com/black-screen.html#Dimbulbs
Mar 23, 2017 | Compaq Presario CQ60-212US Notebook
The screen is not turning on even though the rest of the laptop is working. how do i fix this?
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 16, 2009 | Compaq Computers & Internet
Acer 6920 LCD Screen damaged
The screen is impossible to repair if its cracked. Getting a new LCD isn't that expensive but only if you know how to replace it. Getting one from manufacturer is around 130. but there is an ebay link on the bottom you can get one for 70 or so with shipping.
This link shows you how to replace a LCD screen. even tho its not your model but is very close to how yours look.
http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-acer-aspire-3620-laptop/
This is the link to a new LCD screen for your laptop.
http://cgi.ebay.com/NEW-ACER-ASPIRE-6920-LAPTOP-LCD-SCREEN-16-WXGA-GLOSSY_W0QQitemZ350199312405QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5189817015&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A15%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
May 12, 2009 | Acer Aspire 6920 Notebook PC
Dim Screen when Power is Unpluged
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 27, 2009 | Dell XPS M1330 Notebook
HP Pavilion dv1000 Notebook PC display not coming on
Does the laptop power up even though you can't see an image on the screen?
Connect an external monitor to your laptop and powe it up, if you see the normal Windows images then the laptop is OK and the problem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 22, 2009 | HP Pavilion dv6000t Notebook
SCREEN SUDDENLY WENT DIM
One of 2 things happened....
1) You Blew the Power Inverter... The Power inverter is a thin rectangular circuit board that plugs into the display panel cable and also powers the LCD Bulb.. If This Part Fails - You Lose Light to the Display even though the display will still be on and viewable against a bright light....
2) The LCD Bulb is Faulty... When the LCD Bulb Fails it will typically give pre-warning signs- though not always.... It will give signs like the whole screen has a light orange or pinkish tone to it, but eventually it will blow and no light at all to the Display Panel....
Both Of These Are Repairable....
The Power Inverter Can Be Purchased Off of Ebay, For Around $15 to $30
The LCD Bulb Itself is also Replaceable.. Though It is a Job Only to Be Performed By An Experienced Laptop Tech... Bulbs as well can be bought off of ebay for a few bucks..
Feb 13, 2009 | IBM ThinkPad T30 Notebook
Computers & Internet Logo
76 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
