Question about Lexmark C534dn Laser Printer
Display is blank and the light is red
The display is blank but the back light is on.
Press the checkmark button the printer beeps 3 times what wrong?
Cold reset hp p4515
Power off the printer, power the printer on and when the memory count starts in the display, press and hold the checkmark button until all three lights on front stay on. Release the checkmark and use the up arrow until display reads "cold reset" and then press checkmark again and printer will restart.
Apr 15, 2014 | HP P4515n LaserJet Printer
My ps3 is not working through the hdmi cable. There is sound but no picture. I've tried in different ports but its the same every time.
Follow these very simple steps to reset your display :-
Step 1.
Turn the Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The console will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep
Step 3.
Wait for the Playstation 3 display to initialize.
Your Playstation 3 should now display properly and you can get back to your gaming!
Hope this tip helps you out
Dec 31, 2010 | Video Game Consoles & Games
My boyfriend unplugged his ps3 at his house and brought it round to mine and it will not work in any of my televisions why is that?
Hi there, you need to reset the display back to standard definition. Follow these steps :
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you first press it and then beep a second time about 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for your PS3 display to initialize.
Hope this helps
Oct 24, 2010 | Sony Playstation 3 (PS3) Console
Change my display setting
Do the following steps to solve your PS3 problem :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Dec 12, 2009 | Sony Playstation 3 (PS3) Console
When trying to print it says
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults.Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Aug 30, 2009 | HP LaserJet 3015 All-In-One Printer
How do i turn off the fax confirmation print
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
Aug 12, 2009 | Office Equipment & Supplies
Lexmark c530dn red light on
Operator panel display blank, five beeps, and LED off
Service tip: The printer has detected a problem with the system card, the operator panel assembly cable (part of
the top cover access assembly), or the operator panel assembly if POST does not complete. The printer emits
five beeps, and sticks in a continuous pattern until the printer is turned off.
Is this what you are getting?
Mar 12, 2009 | Lexmark C530dn Laser Printer
Hp deskjet 5552 how to reset?
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults. Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
HP 2200 -
Cold reset:
4. Release GO.
NVRAM Reset:
4. Release GO.
HP 5P & 6P
Cold reset:
Reset the NVRAM:
Dec 02, 2008 | HP DeskJet 5550 InkJet Printer
Laserjet 3600 HP printer in wrong language in display led screen
When you say writing, I assume you mean the language on the printer's display. Here's a step by step guide (since I assume you can't read the Japanese).
Press the blue Checkmark button to access the menu system. Press the down area twice which will give you access to the configuration menu. Press the Checkmark button to select this menu. Press the down arrow twice to access the system setup menu. Press the Checkmark button to select this menu. Press the down arrow 13 times (you can just keep pressing it until it gets to the bottom. It won't go any farther than the last entry) to get to the very last entry which is language.Press the Checkmark button to select this menu. The languages will be displayed in their native scripts. The first one is English. Press the Checkmark button to select English. And you are done. Press the U shaped arrow to get back to the main menu.
Sep 20, 2008 | HP LaserJet 3600dn Printer
Lexmark C534dn Laser Printer Logo
345 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
