Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Ice Jam in Chute - Whirlpool IDI SxS
I wanted to get some feedback on what could be causing the freezing in my ice chute and ice bucket on my Whirlpool In Door Ice SxS.
The unit was recently purchased and has frozen up already. The ice bucket appears to have ice around the lower chamber and some frost build up in the chute. Ice bucket does not look like my old IDI refigerator bucket.
  • Judy Montgomery
    Judy Montgomery Jan 02, 2008
    my whirlpool ice maker in my side by side refridgerator freezes up and makes ice can i un freeze chunks to see what might be causing problem?the water comes out for a cold drink chute.need ice chunk out badly.fridge is about 10 yrs. old. thanks
  • 410 Answers
First check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Posted on Dec 11, 2007
My Whirlpool 2 Door Frige & Freezer Tice maker outlet Chute Freezes up and blocks flow if ice coming down
you need to replace ice chute flapper. on alot of side by side whirlpool refrigerators there is a seal kit to solve that problem.
Jan 26, 2017 | Whirlpool Refrigerators
My Kenmore ice and water in the door refrigerator has the ice in the storage bin freezing into big clumps of cubes and the dispenser forces the bin out of position. It acts like the icemaker is getti
There may be ice forming in the water chute causing water to spill out of the chute and pour onto the ice in the bucket. Sometimes the water valve has a slow drip or is slow to shut off. the valve may need replacing. I doubt it is the icemaker but it could be.
Oct 04, 2014 | Refrigerators
The ice does not dispense from the chute. The chute freezes up and the ice can no longer travel down the chute and out the dispenser. Can this be fixed?
Yes the flap is supposed to close completly to stop the moist kitchen air freezing in the chute and blocking it
Sep 19, 2014 | Refrigerators
Whirlpool GD5RVAXVY05 dispensing problem
yep replace the motor and she is back to normal
Mar 22, 2014 | Whirlpool Refrigerators
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Water leaking from behind ice chute door & freezes under ice bin
You will have to remove the unit and access the rear of freezer. Check that the filters are not plugged as well as drain.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice in bucket freezes into a lump, mechanism freezes
it sounds like the ice chute door is stuck open. on this model it can slip off the "hinge pin" or the plastic that holds the pin can break. if the flap is broken it is replacable. the pin can be put back in. if the plastic that holds the pin is broken, you need to replace the whole door. expect to wait 6-8 weeks for a new door, sooner if lucky. cost is $400 +++ more for stainless.I hope the pin fell out. hope this helps
Jun 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side ice maker freezes up. can't get ice out of
Can you give more details?
If the ice chute is frosting up, chute door is not sealing, air , with moisture, is getting in and freezing. An ice cube getting trapped by the door will cause this also. Either case, replace door and delay mechanism.
May 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Nov 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
729 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
