Question about Panasonic Audio Players & Recorders
Panasonic hi-fi model SA-VK925D 5cd changer.the cd mechanism is out of alighnment,so how can i alighn it because i do not know the set up of the gears and the trays.
  • 6 Answers
SOURCE: Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Posted on May 01, 2008
SOURCE: Panasonic SA-PM193 5cd stereo system
how do I have all 5 cd's play one after another automatically?
Lost our manual.
Thanks
Posted on Jun 19, 2008
SOURCE: My panasonic SA-AK750 hi fi
Hi
The problem is mechanical, Disassembly carefully the section mechanism, clean all with isopropilic alcohol and grease again.
Posted on May 15, 2009
SOURCE: panasonic sa-ak20 5 CD changer does not work
hi i heared about you cd changer problem. i have a same hi-fi system an i have the same problem. it seems it appears when you hit.move or turn upside down the cd changer. you can solve it by unscrewing the top of the hi-fi with a regullar screw there should be 5 screws on the back and 4 on the sideways after this take the top off by pulling it upwards then you should plug in the hi-fi at the outlet and try to change the cd if it doesn't work try seeing if any of the cd is stuck in there if it is try to push it with your fingers but watch your fingers and do not touch any metallic part if in doesnt work like this eithertray looking if the cd-reader is stuck in any way......try to free it with your fingers but watch your fingers too if it doesnt work try to contact me at :tavi0815@yahoo.com il help you with any sound-sistem problem :D ;)
Posted on Jun 20, 2009
  • 4 Answers
SOURCE: anyone have service manual for Panasonic SA-PM18?
Yes, you have to destroy your Panasonic SA-PM 18 with a srewdriver and than meet the CD changer with a hammer. If this doesn't help you must take this changer into a box - wait a few years and than throw it in the waste. ::))
Posted on Aug 11, 2010
Need alighnment setup for CD changer please.
Go to the manufacturers website and download the setup CD from there!
Aug 09, 2015 | Audio Players & Recorders
Panasonic 5cd mod.# sa-ak18 won't play why
Presuming that other sources work okay and the the cables are connected correctly.....Try a CD Lens cleaner.
If that doesn't work then it's time to open up the unit and manually clean the laser lens. If that still doesn't work then the laser might be dead. Replacement parts may be available. Whether or not you can do this as a DIY repair though is questionable. It depends on your skill.
Sep 16, 2014 | Audio Players & Recorders
Looking for a manual on a panasonic sa-pm31 bi-amp,5cd changer,can u help ?
Here's the link for the online manual from Panasonic. Let me know if this is useful.
http://service.us.panasonic.com/OPERMANPDF/SAPM31.PDF
Nov 12, 2010 | Audio Players & Recorders
My panasonic SA-AK750 hi fi stereo keeps saying disc change error and the changer will not open or change disc. ive tried turning it off at the wall and then turning it on again but its still displaying...
Tienes que llevarlo a un centro de reparaciones ya que el sistema de cd esta fuera de tiempo por eso no funciona nada.Hasta que no lo pongan a tiempo no va a funcionar.
Apr 06, 2008 | Audio Players & Recorders
Convergence not alighning tv screen
No you cannot! There is a switch on the convergence pnl for complete convergence. You can make things 10 times worse if you don't know what your doing.
Mar 07, 2008 | JVC AV-56WP30 56" Rear Projection...
Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Oct 06, 2006 | Technics SL-MC6 CD Player
Fault
Ok man first thing I need to know did you decide the Pickup assy was bad or did a repair shop?? I fyou did or the repair shop how did they come to that conclusion??? if a pickup is truly bad you cant just repalce it and expect it to work No my friend Im not saying your stupid or any of the sort just uninformed maybe.. If a pickup assy is replaced you must first off have the service manual to see where the rf terminal is to connect your scope to look at the rf pattern. Now you also must have the serviuce manual to perform the focus and tracking Offset adjustment as well as the focus and tracking gain alighnment. First thing you wanna do is adj the offset adjustment as this will set the focus and tracking coils in a center alighnment for the gain Now this is a very important adjustment my friend as if the offsets off on focus it wont play certan disc and if the tracking is off alighnment it will skip all over all of a suddenly for no reason. Now you must have a scope to see what bthe rf pattern looks like to do any sort of alighnment or to see what bthe state of the laser is in. as sometimes even new laser assys. need whats called a grating adjustment and you really need the right tools as well as the right equipment to do these adjustments with . A laser pickup dosent go out as often as most servicers says it does as there was a servey done with the Mishuta corp( panasonic) and 85% of returned pickups were not defective and should not have been replaced. Now im not sure on how much experience you have with this stuff but if your a hobby type repairer thats great but please you may be over your head so see if someone with the proper eqipment as well as the proper tools can assist you in this repair. And I do think its a good thing that you are trying My friend But without the right service manuals as well as the proper tools your spend a bundle and get Now where??!! GOOD LUCK
May 21, 2006 | Panasonic SC-DK20 System
310 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
