Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson Stylus SX100 General Error
Flashing lights, no movement from barrell or paper when turned on or off. Need to fix this pronto!
  • 1,218 Answers
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point. get more information and help from here . Hope this helps you.
Posted on Sep 01, 2010
4 Suggested Answers
aicaxz
  • 511 Answers
SOURCE: epson r230 general error
Blink alternately or not? If alternately, the message is not "general error". but "service required" It's true to reset waste ink counter. But, i think it's not service required. when trun on printer ready? But when start to print red lights blink at same time? Problem with chip at ink tank. Check connector at chip and at head carriage. It's may be dirty, and not good connection. try to use another chip.
Posted on Jun 24, 2009
SOURCE: General error for epson stylus T10
green & red light blinking cant print epson t10
Posted on Dec 07, 2010
SOURCE: general error in epson stylus
HOW TO FIX MY PRINTER, IT DISPLAY A GENERAL ERROR, AND BOTH RED AND GREEN LIGHT IS BLINKING.PLS HELP ME..TNX
Posted on Jun 14, 2011
My epson l800 write ,general error, open the printer cover and remove any paper inside the printer .turn the printer off and delete all print jobs ,turn the printer back on.am already try all but still...
Fix Epson Stylus Photo 6 Colors Printer General Error Problem
? 1:02
https://www.youtube.com/watch?v=Ci9MWG7zAkM
Dec 1, 2013 - Uploaded by TechRePair
Fix Epson Stylus Photo 6 Colors Printer General Error Problem. TechRePair ... ???????? Epson L800, T50, P50, R290, R295. User dismantling ...Missing: write
Epson General Error Problem + EPSON Adjustment ...
? 5:05
https://www.youtube.com/watch?v=gaKeB5JJqRc
Sep 28, 2014 - Uploaded by Gigi service
Epson General Error Problem + EPSON Adjustment Program / Waste Ink ... Reset Geral na Epson T30, T33, T50, T1110, L800, XP214, TX133 e ...Missing: write
epson l800 general error ' Error Help
Feb 10, 2015 | Epson L800 - printer - color - ink-jet
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
Mar 30, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
How to reset code for Espson C120 Stylus
Flashing alternately can be fixed by using resetter/ adjusment program.
But flashing simultaneously can't be. It's fatal/general error, error that can't be resolved by printer itself.
Jan 20, 2013 | Epson Stylus Office Equipment & Supplies
Ink light and on/off light flashing
Turn printer off for a few minutes then turn back on. If still flashing your cartridges may not be compatible.
Jul 17, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Ink light and paper light flash alternatively, printer does not work
Hi - According to the Epson manual that error indicates that paper may be blocking movement of the print head.
Turn off the printer, then open the cover and remove any jammed paper or foreign objects. Turn the printer on. If the lights continue to flash you're most likely going to need a dealer service.
Hope it's the paper.
Good Luck, Mikeywaf
Feb 28, 2011 | Epson Stylus C66 Inkjet Printer
Two red lights flashing, but i can't figure out what's wrong
According to the documentation for your printer.
Red probsolv.6.3.11.jpg paper and probsolv.6.3.12.jpg ink lights flash alternately Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, contact your dealer or Epson as described in Where To Get Help.
Dec 16, 2010 | Epson Stylus C86 InkJet Printer
Inserting A4 paper
maybe this Site helps.
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20SX100-_E
Here you can find many documentations e.g. for your Epson Stylus SX100
Jun 02, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Epson stylus photo r300 general error
Hi--I had a BIG problem, day after day, fiddling with my Epson Stylus printer. The "General Error" kept repeating, and the two red buttons flashing each time I turned the printer off and on. There was nothing jammed at all. So, as a last resort I took a paper towel and ran it along the bottom of the inside of the printer (yeah--all technical jargon, I know--not a computer person here :-) and a bunch of black ucky stuff came up. MY PRINTER WORKS NOW! Hope this helps someone else. I saw a lot of posts where people said to throw out the printer and start fresh when my problem happened, but what an easy fix. GOOD LUCK!
Nov 26, 2008 | Office Equipment & Supplies
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
997 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
