Question about Kenmore Washing Machines
Washer will agitate but will not spin and drain. It is a . Can I fix this problem myself?
    President:
  • 1,653 Answers
Sounds like the controller is faulty. Turn off the machine at the mains and leave it off for 60 minutes, Turn it back on and see if it has cured the problem. If not it would be best to call a repair man.
Posted on Sep 11, 2009
My washer will not spin/drain
check in ubend tube should be under sink had this problem myself and ended up just rubbish blocking it
Jan 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
My washer stopped spinning and agitating its a whirlpool how do i fix
hi robbie,it has to drain before it spins check the pump for blockages other faults could be module board this control the spin speed. not sure where it's located on your machine but they usually sit at the back of the washer may have a load of wires coming off it. bushes can cause this fault. with the power off stick a multimeter on the pump see if not open circuit hope it helps
regards
shaun
Oct 24, 2011 | Washing Machines
My 80 series kenmore washer will not agitate unless I push down on the center of the part that agitates. it pins fine. is this something I can fix myself? is it worth fixing or should I look at replacing...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
In answer to your other questions:
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
Oct 24, 2009 | Kenmore Washing Machines
Whirlpool Duet Washer won't spin
Sounds like the whirling noise is the pump, pumping. Does it drain at all? Check the drive belt and make sure that it is not broken. This system uses a drive belt with a clutch system to agitate back and forth. The clutch system could be bad as well.
This might not be a cheap fix, these are the main components of the system
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer not spinning
Probably drains though right? But does not spin or agitate? Sounds like your motor coupler is broken. You can get a tutorial and the par so you can fix it yourself here:
www.shop.washermd.com Dave
Jan 13, 2009 | Washing Machines
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
Amana NAV2330 Wont Agitate or Spin
i would assume that perhaps you did not wind hte belt correctly arround the legs of the pump and therefore are not putting the correct tension on hte pulley(remember to hook spring back up to tension idler?)
Dec 08, 2008 | Roper RAS8445KQ Top Load Washer
Whirlpool top loading washer doesn't agitate
The agitator dogs only make the top part of the agitator work. you can check the dogs by grabbing the top of the agitator and turning it right then left. If it doesnt lock when turned back the other direction they are bad. If thats not it, it could be your drive coupler. But its only the drive coupler if it doesnt spin. Also check the lid switch. But if its the lid switch Your washer will stay full of water and not drain out. But check your dogs. There are cheap and thats probably your problem.
Nov 16, 2008 | Washing Machines
Washing Machines Logo
19 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
