Question about Indesit W 123 Front Load Washer
Water will not drain away - Indesit W 123 Front Load Washer
  • 3,741 Answers
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Sep 11, 2009
Washing Machine won't drain away water.
Hi, can you hear the pump running when you select a drain program?
Mar 11, 2013 | Washing Machines
Candy intergrated fridge, the drain away does not drain water away, what is the best setting for keeping items cool and ensuring the drain away works
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 30, 2011 | Refrigerators
Water does notdrain away
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jul 21, 2010 | Bosch 24 in. SGS4072 Free-standing...
The water starts to go in but drains straight away.
If the drain hose is too low and below water level the water has no reason to stay in the machine, and will flow straight through. If the water is pumping out during fill, you have a technical problem....Good luck....Nomess
May 20, 2010 | Washing Machines
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Water is not draining away throguh the hole near
the drain is probably frozen, unplug unit and defrost manually, use a hair dryer to melt the ice around the drain , be careful not to melt any of the plastic
Nov 03, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Hotpoint BF162............. Water left, not draining
Open the bottom panel of the washer and see if it is full of water, if it is drain it away and clean all of the filters inside the washer and reset.
Mar 04, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Indesit W 123 Front Load Washer Logo
255 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
