Question about Microsoft Xbox 360 Console
Xbox 360. problem code E73 . playing call of duty 5 when the screen went greeen and lines went down the sreen like an atari or something. a red cirle appeared around the power button, when i turned my xbox off then on again it had the code E73
  • 3,741 Answers
The problem with e73 is that its the system telling you there is a problem with the ethernet cable reciver but there may or may not be. 90% of the ,consoles i come across have not been a problem with the ethernet reciver at all some of the more popular problem flashing this code is a result of system failure in the mother boards ability to read properly the connection between the cpu and gpu units under the heat sinks. there are a few fixes avalible for this projected e73 problem. i strongly caution you not to preform work unless you are familiar with the console and its internal parts. ------- I cannot guarantee that this will work for everyone to fix it.
Remove the A/V cord from the back of the XBox 360. Stick two sticks into the fans to prevent them from spinning. This will cause the system to overheat within five minutes. You will know its done when the first and third quadrants light up red on the system (indicating the system has overheated). Unplug the system, plug it back in and turn it on to see if it was successful. (Note: While this method does not void your warranty, if your XBox is still under warranty I suggest sending to Microsoft to fix.)
Posted on Sep 11, 2009
Xbox-360 elite lower right hand red flashing led light code error E73
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 17, 2011 | Microsoft Xbox 360 Console
Xbox 360 Console: one red light code E73 appears on screen...
your xbox is going to die..
but there is a way that you can play it.just heat up your xbox for couple of mins.then try again.it works.
every time you see E73 error just do this
for more help email me how to do.
azibajwa@yahoo.com
May 17, 2010 | Microsoft Xbox 360 Console
One red light and a e73 error code??
Hello sir
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
May 15, 2010 | Microsoft Xbox 360 Console
When i turn on my xbox 360 it turns to a black screen and says i have error E73 and when i went to Xbox.com it didnt say anything about it
Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
Apr 14, 2010 | Microsoft Xbox 360 Console
E73
http://www.xbox-360-red-lights.com/solving-xbox-e73-error
Got the Xbox 360 E73 error? Want to get it fixed? Fact is that this problem may be tough to fix, and that's why many people will tell you to send your console over to Microsoft and pay $150. But is it really worth your $150? Is there maybe another way to get it fixed? The Xbox 360 E73 error may be tough to fix, but this doesn't mean that you can't repair it by yourself.
3 ways to fix the Xbox 360 E73 error
1. Restart your console.
2. Unplug all AV cables, and also unplug the power cord from the wall socket. Once that's done, plug them all back in correctly, and put your console back on.
3. Take out the hard drive, and put your console on. If the troubleshooting error has been gone, put your console off, and get the hard drive in again. Than put your console back on.
If these tips didn't fix your Xbox 360 E73 error, you will have to open up your console, and fix the problem from within. You can do this by 2 ways. You either send it over to Microsoft, or you will actually repair the troubleshooter by yourself with a repair guide.
Fix Xbox 360 E73 error by Microsoft or by myself?
So what to choose? Well, if you send your console over to Microsoft, you will have to pay $150 if your warranty has been expired. Also, you will have to wait for 2-6 weeks before you can get back to playing. You'd better want to avoid this... Right?
It can be done way faster and cheaper... If you fix the Xbox 360 E73 problem by yourself, you will be able to get the problem fixed without spending $150. But, you will have to spend a little money on a repair guide, because that's what you will use.
You will use a repair guide, because it gives you step by step instructions that's including photo's and videos, so you will be able to open up your console, and fix the Xbox 360 E73 error very cheap and easily. See it for yourself, visit: Xbox 360 Repairs
Also, when you fix the Xbox 360 E73 error by yourself, you will be able to get it repaired in less than 1 day, or even within 1 hour. It's done before, so why wouldn't you be able to do it either? Want to play your favourite games again, today? Get yourself a repair guide, visit: Fix E73 Error
Apr 13, 2010 | Microsoft Xbox 360 Console
Xbox 360 E73 error. What do I do?
Apr 07, 2010 | Microsoft Xbox 360 Console
Xbox 1 flashing red light and e73 system error
e73 is an input/output error. Hopefully you are still under warranty. Contact Microsoft at Toll free: (800) 4MY-XBOX or (800) 469-9269. If you are outside of your warranty period, I believe they will still repair it for $99
Feb 21, 2010 | Microsoft Xbox 360 Arcade
Red flashing light on bottom right on 360 elite (e73 error)
X-clamp Fix. Also make sure you have all four heat patches attached to your memory chips. If you don't have any buy some. They sell them on the net.
Jul 14, 2009 | Microsoft Video Game Consoles & Games
I turn my xbox 360 on and it comes up with the problem mesage E73
Red Ring of Death, or Processor Failure. Call Microsoft and they'll send you a new one, once you send yours in.
Jan 31, 2009 | Microsoft Xbox 360 Console
Xbox 360 error code e73
The Internet Port or Referred as the CPU or GPU is fried and needs to be turned in the Microsoft for repair. No other way that i Know will fix it.
Jan 12, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
139 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
