Question about Toro Lawn Mower With Toro Power Tools
Toro starts wont accelerate then dies will restart then dies again will accelerate if i push linkage but will not on its own
2 Suggested Answers
sparksflyin
  • 47 Answers
SOURCE: toro powerlite ccr model#38175
seems to me you have water or dirt in you carb pull the carb off take the bowl off clean it real good try to do so over a bowl or bucket to see the fuel that comes out to determine if its water or just dirt
Posted on Feb 05, 2009
Car will not accelerate after recent tuneup!
You must have disconnected something on the throttle linkages when you changed the gasket. Also look for wires off sensors.
Jan 22, 2016 | Cars & Trucks
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
Jul 19, 2014 | Toro Garden
How do I fix the clutch on Toro Consumer 71184, 12-38XL?
have u checked the spring or cable or linkage
May 24, 2014 | Toro Garden
Toro rider 16-38 HXL when I start it revs at FULL speed and sounds like it will blow up. I slow it down with choke all other linkage seems to be in place properly- Is there a trick to fixing?
Three options:
1. The carburetor throttle plate (closest to the engine is stuck); clean it with gumout and work it back and forth
2. the linkage is hooked in the wrong hole ; check the wear pattern on the throttle shaft plate to see if it is in the wrong hole.
3. The govenor arm or gear is not adjusted properly; loosten the govenor arm, push the throttle plate of the carburetor all the way closed. push the govenor arm the same direction all the way until it bottoms out. tighten the arm clamp. Test again
I recommend getting a manual or at least a free parts diagram from a local shop like www.arcolawn.com
Good luck
Joe
please vote me up if the fix was good.
Dec 29, 2010 | Toro Lawn Mower With Toro Power Tools
Toro lawn mower wont start
pour alittle gas in carburator & then try starting see what happen if it starts & then dies then you have a carburator problem
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
Lawn mowewr wont restart
Check the gas cap. Loosen it a bit and try again. There is a vent built into it the hole on top plugs up ans stops the fuel flow.
Eric
Jun 24, 2009 | Toro Lawn Mower With Toro Power Tools
Oil causing a problem?
Sound as if you have too much oil in the machine. Anytime you see white or lite gray smoke it is a sign of too much oil. Before you go through the routine of cleaning the oil out of every nook and cranny, try unscrewing the spark plug and clean it with a soft rag. It would have oil on it preventing the machine from starting. If this does work and there isn't a lot of oil in the gas tank now, just continue running the engine until the smoke clears. It won't hurt anything. But if cleaning the plug doesn't help you will have to empty all gas and oil from the gas tank, refill with new gas, squirt a little gum out carb cleaner in your carb to remove any oil there (this can be done when you try to restart the engine). Remember, when you are mowing grass if you are mowing on a hill) of any knd, make sure to turn the mower so the gas tank is on a higher level than the oil.
Jun 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro powerlite ccr model#38175
Feb 02, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
138 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
