Question about Microsoft Windows XP Professional
Cannot download windows XP service pack 2 as it says my copy of windows is not original does this matter and also told it helps if you have it with wireless reception better
    President:
  • 1,179 Answers
Yes it matters. Only those that pass the Genuine Windows test will be allowed to update as anything else is considered pirated software by Microsoft. Your only solution in this case is to call Microsoft and explain your situation to them. They may or may not issue a replacement key depending on situation. Good luck.
Posted on Sep 11, 2009
Windowsxp2 validation process not genunie
http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
if you have a copy of windows service pack there is a program that allows you add service pack 3 to it so you have a copy of xp sp3
http://www.nliteos.com/changelog.html
Add external drivers and Windows updates to your original Windows XP installation CD
Microsoft Windows XP Professional SP2
RHKG3 8YW4W 4RHJG 83M4Y 7X9GW
V2C47-MK7JD-3R89F-D2KXW-VPK3J
i have done this and now have a legitimate copy of xp pro sp3
hope it helps
Jun 07, 2012 | Microsoft Windows XP Professional With...
Tip
Upgrading Windows XP
Most users of Windows XP are using Windows XP service pack 2.
You can upgrade Windows XP service pack 2 by installing plain service pack 3.
This will upgrade and improve functionality to your current installation to Windows XP.
There are alot of versions of Windows XP Service pack 3 but i recommend downloading an official version from Microsoft's downloads center through the link below.
To after download is complete, install the file. Installation takes about 10 to 30 minutes depending on your system specifications.
If your current installation of Windows XP has too many errors, installation of service pack 3 may not be successful.
The solution to this is to reinstall your Operating System (OS) using your OS installation CD, then install Service pack 3.
How ever, OS re installation will erase all your data in your system partition so back up all your data.
To download an official copy of Windows XP service pack 3, follow this link:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
on Jan 07, 2010 | Computers & Internet
I HAVE TO DOWNLOAD
windows xp does not have a copy that is downloadable
if you currently have a copy of xp
if you need more help with this post a reply
hope it helps
Jun 07, 2012 | Microsoft Corporation Microsoft Windows XP...
What is the installing code of Microsoft windows Xp service pack -2?
If you have a "valid" (not a "bootleg") copy of Windows XP, then there is *NO* "code" required to install XP Service Pack 2.
However, as of this month, Microsoft no longer supports XP Service Pack 2 -- you need to download/install XP Service Pack 3, in order to be supported.
Aug 04, 2010 | Computers & Internet
How i can make a bootable Windows CD for my personal use
Create a temporary working folder at the root (top) of the C: drive called "XPSETUP" (without the quotes). Actually, you can name it anything you want and put it anywhere you like, but for ease of explanation, the remainder of the steps below will assume that you have created the XPSETUP folder in the root of drive C:. This C:\XPSETUP folder will be where you will create the CDROM directory structure for your bootable Windows CD.
Copy the entire C:\I386 to C:\XPSETUP. When you have finished, you will have C:\XPSETUP\I386. Notice that I said "copy", not "move". Do NOT drag and drop the I386 folder into the XPSETUP directory. If you do so, you may end up moving it into the XPSETUP folder (depending on where you created the XPSETUP folder). It is important to work from a copy of the I386 directory so that if you make mistakes, you can simply go back and start all over again. If you move the directory or drag and drop it, and you make a mistake, your mistake will be permanent. So once again, COPY the entire I386 folder to XPSETUP. It may take a while for the copy operation to complete, but it's safer this way.
If you're not sure how to copy, follow the following procedure: Highlight the I386 folder using Windows Explorer. Right-click the folder and select "Copy". Then open the XPSETUP folder. The folder should be empty at the moment. Right click the empty space in the window and click "Paste". A very lengthy copy procedure will take place.
To verify that you have copied the folder and not moved it, return to the top of C: and check that the I386 folder is still there and that the original files in that folder are still there.
Create an ASCII text file with only the word "Windows " (without the quotes and including the final space after the word "Windows") in it, followed by a new line. To do this, open up Notepad. Notepad can be found in your Start menu -> Programs -> Accessories -> Notepad. Type the word "Windows" without the quotes and following my case exactly (that is, "W" is a capital letter and the rest are in small letters). Then type one additional space. Finally, hit the ENTER key. Do not add anything else to this file. Do not change anything - for example, do not type everything in capital letters or anything like that. The contents of the file must be exactly as I said, or Windows setup will issue an error message.
Save the file with the filename "WIN51" (include the quotes so that Notepad will not add a ".txt" extension behind your back) in C:\XPSETUP. Again, the filename's spelling and case must be exactly like mine.
If your PC or laptop originally came with XP Home, make a copy of the file you just created and call it "WIN51IC". If you are using XP Home Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IC" and "WIN51IC.SP1". If you are using XP Home Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IC", "WIN51IC.SP1" and "WIN51IC.SP2". All the copies of the files should be in C:\XPSETUP.
If your PC or laptop originally came with XP Professional, make a copy of the file you just created and call it "WIN51IP". If you are using XP Professional Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IP" and "WIN51IP.SP1". If you are using XP Professional Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IP", "WIN51IP.SP1" and "WIN51IP.SP2". All the copies of the files should be in C:\XPSETUP.
Note carefully what I said above. You may be running XP SP 2 now, but if your PC came with XP SP 1, you should create the files for XP SP 1. There is an exception to this. If your PC or laptop came with XP or XP SP 1, but you want your Windows install CD to install XP SP 2, create the WIN51 files needed for SP 2 and follow the procedure for slipstreaming Windows service pack 2 (SP 2) into the Windows setup CDROM given in the next step.
If your PC or laptop came originally with XP or XP SP 1 (service pack 1) but you want your Windows setup disk to install XP SP 2, do the following. Otherwise, skip to the next step.
Note that even if you have since updated your computer to SP 2, you will still need to do this step if you want your setup CD to install Windows XP Service Pack 2. The reason is that updating your running Windows system does not automatically update the I386 directory. Your I386 directory still contains the Windows setup files belonging to whatever version of Windows you had when you first bought your PC/laptop.
Download Windows XP service pack 2 from http://www.microsoft.com/downloads/details.aspx?FamilyId=049C9DBE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en Save it anywhere you like except in the C:\XPSETUP folder. For the purpose of this tutorial, I will assume you saved it as C:\XPSP2.EXE, that is, in the root folder with the filename "XPSP2.EXE".
Important: if you did not configure Windows to show you the full filename you should probably do so before changing the name of the file. Otherwise, you may be inadvertently saving the file as "XPSP2.EXE.EXE" without your knowing. (That is, you see the filename as "XPSP2.EXE" in Windows Explorer but it's actually "XPSP2.EXE.EXE".)
You will need to update the C:\XPSETUP\I386 folder to contain the updated SP 2 files. As a side benefit, the service pack 2 updater will also create a few files (including setup.exe) in the C:\XPSETUP folder. This process of integrating the service pack files into the original XP or XP SP 1 is known as "slipstreaming".
To slipstream SP 2, first open up a command prompt. To do this, click the Start menu, select the Run menu item, and enter the words "cmd". Click the OK button. A black command prompt window will open.
Enter the following line into the window and press the ENTER key.
C:\XPSP2.EXE /integrate:C:\XPSETUP
After the program finishes, you can close the command prompt window. If you look into your XPSETUP folder, you will notice a few new files there.
At this point, the C:\XPSETUP directory contains all the files that will be copied to your Windows Setup CDROM. Don't worry if the directory does not contain files like "setup.exe" which you see on the retail CDROMs. You won't need it for a fresh install from the bootable CDROM. Note: You will only have "setup.exe" if you had to slipstream Service Pack 2 as mentioned earlier. The Service Pack 2 slipstreamer creates setup.exe for you.
Now open the wxp10.zip file that you downloaded earlier. Simply doubleclicking it in Windows explorer should do the trick. Go into the cds directory and into wxphome (or wxppro; it doesn't matter which) directory, followed by the files directory. Drag the "w2ksect.bin" file into C:\ (the root directory/folder of drive C:). Don't get creative and place it in some other directory. If you do that, ImgBurn will not be able to find c:\w2ksect.bin later.
You could do all that OR simply download an XP LIVE DVD.. This will  bootup from DVD and work without using/installing to the Hard Drive.
here is the torrent DL link No torrent?  Here > http://www.utorrent.com/
DL and install.. then click on torrent link and it will DL.
http://thepiratebay.org/torrent/3820108/Windows_XP_Live_Edition(Run_Windows_from_CD)
here is a link how to make it.
http://www.intowindows.com/how-to-create-live-usbcddvd-of-vistaxp/
Feb 01, 2010 | Microsoft Windows XP Professional SP2
Product key for xp sp 3
You dont need a product key for Service Pack 3 to upgrade from service pack 2.
You can simply download an official copy of Service Pack 3 for Windows XP from Microsoft's downloads center.
Follow the download link to download Service Pack 3, then install it.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Thank you for using Fixya,
Kenneth.
Jan 18, 2010 | Microsoft Windows XP Professional With...
I must update my windows xp and i don;t have a cd-key
You can update your Windows XP service pack 2 by installing service pack 3.
This will upgrade your Windows XP and it will make it perform much better.
Download an official copy of Service pack 3 from Microsoft downloads center, through the link bellow.
Jan 07, 2010 | Microsoft Windows XP Professional With...
PLS CAN I GET A ACTIVATION CODE FOR WINDOWS XP PROFESSIONAL SERVICE PACK 3
If you have a VALID XP license there is no activation code for the service pack.
You download it from Microsoft who will evaluate if you have a legal copy of Windows XP and will install the service pack. If you have a pirate copy they will document it and refuse to install the service pack.
Go to the Microsoft site and have them scan for updates for you.
Dec 08, 2009 | Microsoft Windows XP Professional With...
FULL VERSION OF XP PRO TO DOWNLOAD ?
sir, i have a original cd Version: 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) one month trial with key but do not have unlock key. please, if possible.
thankyou,
Dec 04, 2008 | Microsoft Windows XP Professional
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
21 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
