Question about Hammering
Waker plate with honda g100 2.5hp engine leaking oil
Iv got a waker plate with a honda g100 2.5 hp engine which leaks oil when running how do i find the leak?
  • i am after a manual for a honda G100 modle
Posted on Mar 02, 2011
  • 251 Answers
Jet wash it clean , then get an old tyre and start up the **** leave it on top of the tyre and just observe , we commonly used to find a small oil leak from the filter foam wiith folk leaving them on there side
Posted on Oct 23, 2009
Engine oil consumtion problem - 2009 Hero Honda Splendor Plus after clutch plates changing
1st check your engine if theres a posible leakage like main driveoil seal,cam shaf oil seal, oil filter. if thres no leak check engine breather if it is produces smoke. posible causes ; valve seal is loosen or piston ring is loosen.
Aug 21, 2015 | Honda Motorcycles
Oil leak at bottom of timming belt cover
what engine.? lots of engines, used. and 21 models of civic, USA.
its usually.
1: valve cover, (yes, most can leak from top down behind the belt.
2: cam seals
3: crank end seal
4: oil pump seals.
6: oil pan ( last choice)
finding oil leaks takes hard work , clean, it find it .
or use the dye kits.
gravity and wind, allows it to go where ever IT wants.
so it must be clean first to find it.. see?
or use the dye kits, it shows a live leak best.
ever look here?
http://estore.honda.com/honda/parts/view-honda-parts-catalog-detail.asp?m=1997-civic-2-dx-4at&sn=&b=E++09&dl=
question, at the 60k mile service points. you check lash, settings.
with a new timing belt. and at such point, a new valve cover gasket gets fitted, did you? if yes, its not leaking if not>????
the front edge of the VC gasket, leaks down behind what i call
the VC leak hidder, tin pan. plate. behind the cam cog
is a plate, and the VC leaks down from there to the cam seal
then down front of engine, then past crank seal the, to cover.
seen this on all most all OHC engines...
cause, nobody does the 60k or does it and uses the old gaskets.
id look there first. but id dont have service history.
start high work down due to gravity.....
the FSM is here.
see that too. "free" too
http://hondatech.info/downloads/Auto/Manuals/Civic/
Dec 17, 2013 | 1997 Honda Civic
Engine noise
change the coil plate ( starter plate) oil seal & o ring...and change cam chain (timing chain)...
Dec 03, 2013 | Hero Honda Splendor Motorcycles
Honda Self-Propelled Lawn Mower leaking oil?
It is toast you fried the crank/connecting rod, by running it low on oil.
Its hard to say what caused the oil leak, but now it is ruined.
Aug 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Husqvarna YTH2448 engine leaking oil
That sounds like the sump gasket is leaking, sometimes the briggs machining at the sump and head areas are a little rough and a bad fit can allow the gasket to blow,if it is leaking it is actually sucking air in rather than pushing oil out while it is running. You would have to drain oil, remove the engine turn it upside down,remove the oil pump cover plate( 3 small screws) pull oil pump rotor and drive shaft out,remove sump bolts,replace gasket and reassemble.Be sure to use a light coat of gasket sealer like black silicone.
Jul 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
1996 honda prelude oil leak
did you check the steering pump, AC compression pump, etc or other engine components ? it could be something other than the engine.
Nov 18, 2008 | 1996 Honda Prelude
Need engine schematic for oil flow I have an oil leak above the oil filter around the oil pressure sending unit (I think). The filter doesn't have much oil in it, so I think something is plugged. I assume...
hi common fault with hondas change your oil switch it will cure your leak pumps brilliant on these cars plus if oils coming out the pumps working yates210456
Oct 07, 2008 | 1996 Honda Accord
My daughter has 1995 Chevy Lumina with a 425 engine (?) that leaks oil. The intake valve has been replaced and it still leaks oil. The mechanic says he can't place the origin of the leak because the...
I had a '93 Chevy Lumina (sedan) with the 3.1L V6, and it was also leaking oil badly enough to coat the underside of the car with an oily sheen. A mechanic pointed me in the right direction. There is no distributor on this car, but there is a blank-off plate installed where the distributor used to be. The oil pump drive shaft runs off a gear meshed with the cam under this plate, which is also what the distributor used to be driven from. All I had to do was remove the plate, replace the gasket fitted between the plate and the opening, and oil could no longer seep through there. As I remember, I had to remove the air horn from the intake plenum to get at this plate. Hope this helps.
Aug 12, 2008 | 1994 Chevrolet Lumina
Hammering Logo
746 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
