Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper alarm won't arm or disarm and my remote batteres are new. I have a 1996 ford explorer.
5 Suggested Answers
  • 87 Answers
SOURCE: my viper alarm remote just beeps flashes TX and
Try to reprogram this. If this routine does not work please let me know and we will try something else
Posted on Jun 03, 2009
SOURCE: my viper 2 way pager remote will not arm or disarm
It could be set on car #2. Press function for 8 seconds and a light next to lock should come on. If the light next to unlock and lock (two lights) then it is set to #2 car (you can operate 2 cars with one remote). All you have to do is press function again to toggle between the two cars. You want to end up with only one light showing.
So, hold function for 8 seconds, then after a light shows, release and press function until you only see the one light.
Posted on Aug 19, 2009
SOURCE: need to disarm the alarm because the remote is not
i have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
Posted on Oct 10, 2009
SOURCE: viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
Posted on Nov 16, 2009
Car does not arm or disarm when door opened alarm goes off
Hi, I love the viper. Mine worked flawlessly for many years until one time my unit would not arm or disarm. Obviously 1st I checked batteries which were good. I took mine to installer and they said I had a remote go bad. He got me new remote and that was it. Sometimes I wonder if somehow I managed to hit a factory reset sequence on my remote. Considering your also having an issue with door contacts as well, I would hope it's not the main unit. My system also had a special override switch in the footwell, if you have one, perhaps you may have switched accidentally. Hope this helps in troubleshooting.
Dec 18, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Can't disarm even with toggle switch
ususally this happens when the alarm dosent read the door being open, if the alarm dosent read that the door is open you should be grounding out the door trigger (green wire in most alarms) and repeat steps to deactivate the alarm
Nov 15, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5701 led light does not flash when armed, stays lit when alarm is disarmed
If the LED is on solid then the alarm is in valet. To exit valet, press "F" twice then press unlock on the remote. The LED should turn off.
OR,
enter the vehicle, turn the ignition on then off, press and release the valet/programming button on the antenna. LED should turn off
Jan 30, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
When i arm and dis arm system i get error beep?
Hit f and then unlock
You may have lock out the remotes. If that doesn't work DEI has a one yr gurantee on remotes. In your box there should be a registration card. Call them.
Jan 26, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5901, Ford 2008 6.4/ When I use the trucks door keypad
If you use the viper remote to arm the alarm, you MUST use the viper remote to disarm the alrm prior to opening the door. The only REAL solution is to add the keyless entry feature to the viper system, and quit using hte factory remote all together.
Aug 09, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Need new keychain alarm button for 1996 ford explorer
ebay. match part number on back of fob. follow instructions in owner manual to program.
May 23, 2009 | 1996 Ford Explorer
Viper alarm keypad will beep for 30 seconds every time I arm or disarm
May 10, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
When i arm the car how can i hear the sound viper on
whats the make and model fo the alarm? and go to viper.com/support for more information
Feb 14, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Dec 12, 2007 | Viper (VGC421) Remote Control
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
1,492 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
