Question about Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ won't fill with water
I just installed this washer. It's about a year old, has been sitting in my house as I remodel the house. The power comes on, and it starts to run a cycle. Maybe moves once or twice, then nothing for about 20 or so minutes, until it says its done. I checked the hoses, and water flows thru the hoses. The unit isn't drawing any water. Any thoughts?
  • carbonejeffr Jan 03, 2009
    machine wont fill with water or spin
    Genius:
  • 1,003 Answers
REPLACE THE WATER INLET SOLENOID
Posted on Jan 31, 2008
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
My front load GHW9150PW4 washer fills with water when not in use. When the door is opened, the substantial amount of water spills out without warning. There are no locks or anything to keep the door from...
(pre-typed to cover hot and/or cold!)
This is symptomatic of a malfunctioning (not closing completely) water control valve
With power off, if it is hot AND cold fill, turn one or the other off and see which one is causing the problem. Sorry but it needs replacing and a service call ;-0(
If it's cold fill only it's clear which one!!
If is only happens when there is power on it could be the PCB malfunctioning and will require checking by the service call.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 05, 2011 | Whirlpool LHW0050PQ Front Load Washer
I bought this washer used with out a manuel. I
Hello-I came across this several years ago. Some whirlpools have a preprogram where the water temp. is already defaulted to the type of load and color. As you assume the white should be hot or warm. The rest of the selections are probably cold. The manufactures can be driven to apply energy saving features into their products so most cycles are probably cold. If all else fails, when you make a selection let water fill into the tub about 5 minutes and carefully check to see if the water is warmer or colder. You also might be able to pull up owners info on the net if you have the model#.
Feb 08, 2010 | Whirlpool LHW0050PQ Front Load Washer
Washer fills with water, but does not agitate or spin rinse
This could be bad door switch or bad timer. You need to test it with a multimeter
Mar 31, 2009 | Whirlpool LHW0050PQ Front Load Washer
I have a year and a half old Whirlpool LHW0050PQ, that recently started to only run with HOT WATER ONLY.
I have the same machine which lasted about three years before the circuit board went out. Read the reviews on Amazon.com about this machine - it is not well liked by owners. Take off the plastic top with the two screws at the back (you'll need a star point screwdriver), remove the printed circuit board that is held in place by plastic clips and send it to me for $100.00. Take the rest of the machine to the dump - it's a piece of ****!
Jan 17, 2009 | Whirlpool LHW0050PQ Front Load Washer
My duet washer keeps filling up with water even though it isn't turned on. Any ideas?
The water inlet valve is not sealing completely. Replace it. (it's the part the inlet hoses screw onto)
Dec 09, 2008 | Whirlpool LHW0050PQ Front Load Washer
Basically,the machine you have is garbage! - I have one also, It is less than one year old and the repair folks have been out 5 times. It doesn't spin either!
I'd call this one a lemon!
Apr 14, 2008 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ - Water wont empty or fill
This sounds like a plumbing problem. Lets see if we can isolate it. Turn the valves off behind the washer and remove them from the washer. Remove the washer drain hose from the stand pipe. Stuff one of the hoses into the now vacant drain line and turn the water on. Then do the other hose. Any noise? Now reconnect the fill hoses to the washer and reinstall the drain hose to its' place. Turn on the water valves at the wall, set the washer to a cold/cold cycle and start it up. Listen for noise. Now shut the machine off and set it for a hot/cold cycle and turn it on. Listen for noise. If you get no noise now, it's all good. If you're getting noise from just your hot water, your water heater is set too high and you have steam propagating in your plumbing. Your washer water valves (where the hoses connect to your machine) will only do this if you have low water pressure coming from the wall. Still, it'll be a plumbing problem.
Jul 28, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
204 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
