Question about Xerox Phaser 6100/BD Laser Printer
How to enter code to get color copies - Xerox Phaser 6100/BD Laser Printer
  • mich cruz
    mich cruz May 11, 2010
    did u already check the manual for the code?
  • vincent valentine May 11, 2010
    tell me problem properly
Toshiba 2330C periodic maintenance code 00FF?
machine ON .....0+8
code is ....252.... press start button
value input is......0
press Enter Button
time for periodic maintenance is clear.
Apr 01, 2014 | Toshiba E-studio 2330c 2830c Color...
Maintenance require code vc
The VC code on a sharp mx-2700 is the cyan developer has reached its maintenance cycle of 60,000 copies. to clear this code enter sim mode #, *, C, * then 24-5 to clear dv count.
Jan 28, 2014 | Sharp MX-2700N Color Copier
Erro na sharp mx 3100n U2-80
On the control Panel, press the keys #*C* (pound, star,clear,star)to enter test mode. Enter number 16 and press the copy button. On the touch screen press "execute" and "yes". Press CA to reboot. The error code should clear.
Aug 03, 2012 | Sharp MX-2700N Color Copier
Code:fk1 sharp 2301 N
That is a maintanence code. Usually says that the fuser rolls are at a certain copy count.
Here is what to do.
Press in order on the consol. # * C * That will enter the machine into what is called SIM mode.
Then enter the number 24 then 4 for that code, then press execute. You may want to just do the clear all maintenance code too.
Apr 26, 2011 | Sharp MX-2300N Color Copier
How do I put my psc 750 on English it is on Spanish now/
1 Press Menu. 2 Press -> until Maintenance appears, and then press Enter. 3 Press -> until Set Language and Country appears, and then press Enter. 4 Press -> until the desired language appears, and then press Start Copy, Black or Color. 5 Press Start Copy, Black or Color to confirm. A prompt displays asking to select the country where your HP PSC will be used. Specifying the country sets your photo sizes applicable for your region. 6 Press -> until desired country displays, and then press Start Copy, Black or Color. 7 Press Start Copy, Black or Color to confirm
Feb 22, 2011 | HP PSC 750 All-In-One InkJet Printer
Hello there i have a lanier color copier everthing work and functional fine acceipt when i want making color copy, i press full color button the display panel show TO USE THE FOLLOWING FUNCTION [ S ] SET...
Hi, whoever administrates that copier has set it up for key counter management, which means that unless you supply the correct key (which is typically a card that you swipe or a code you enter) you can't make color copies. If this is your copier, you can disable key counter management:
- Press the User Tools/Counter button. - Go to System Settings. - Go to Admin Tools. - Find the option for Key Counter Management and turn it off. - Exit out of User Tools.
Now you should be able to make copies normally.
Dec 02, 2010 | Lanier UNKNOWN
HOW DO I SET IT BACK TO ENGLISH LANGUAGE? ITS STUCK ON SPANISH.
Setting the front panel language
  1. Press the Menu button four times. When the Maintenance setting appears in the display, press Enter.
  2. Press the Right Arrow key four times and press Enter.
  3. The available languages will flash on the display, but they can also be accessed with the navigation keys. Select the desired language by pressing the Black or Color Start Copy button.
  4. Confirm the selection by pressing Black or Color Start Copy button again or press Cancel to try again.
  5. Press the navigation (ARROW) keys until the correct country appears in the display. Press Black or Color Start Copy button.
  6. Press Black or Color Start Copy button again to confirm the selection or Cancel to try again.
Dec 15, 2009 | HP PSC 750 All-In-One InkJet Printer
My HP PSC 750 printer screen seems to be in German. How do I get an English display? Diana
CLICK HERE for your owners manual in PDF format.
Page 36 of the manual states the following -
HP PSC 700 Series
The following steps help you change the language for your unit.
To do this using the front panel
Press Menu.
2 Press until Maintenance appears, and then press Enter.
3 Press until Set Language and Country appears, and then press Enter.
4 Press until the desired language appears, and then press Start Copy, Black or
Color.
6 Press until desired country displays, and then press Start Copy, Black or
Color.
7 Press Start Copy, Black or Color to confirm.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 04, 2009 | HP Office Equipment & Supplies
Cant get it to read in english
Change the front-panel country or language on HP PSC 750. (From HP PSC 750 manual - bpu02250.pdf)
1 Press Menu.
2 Press a194261.gif until Maintenance appears, and then press Enter.
3 Press aa48bd2.gif until Set Language and Country appears, and then press Enter.
4 Press 98782b3.gif until the desired language appears, and then press Start Copy, Black or
Color.
6 Press b3bb801.gif until desired country displays, and then press Start Copy, Black or
Color.
Feb 01, 2009 | HP PSC 750 All-In-One InkJet Printer
Sharp mx 2700n how to go SP mode and i get error code h5.01 how i solve this problem
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
Dec 23, 2008 | Sharp MX-2700N Color Copier
Xerox Phaser 6100/BD Laser Printer Logo
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
