I have a BDP-S360 with a Phillips RC144 that need to be programed. Need the 4 digit code, please.
  • 3,741 Answers
In some cases, you may need or want to be able to turn devices connected to your FiOS TV setup on or off one at a time. Follow the procedure below to program your Philips remote to enable this option:
  1. Press and hold the STB button.
  2. While holding down the STB button, press OK.
  3. Release both buttons.
    The device buttons (DVD, AUX, TV, and STB) blink twice.
  4. Press 977.
    The STB button blinks twice.
  5. Press OK.
    The STB button blinks three times to indicate you've successfully programmed your remote to turn devices on and off one at a time.
Once you've completed this procedure, to turn on or off both the TV and the STB you'll need to:
  1. Point the remote toward the TV and STB and press TV, then press Power.
  2. Press STB, then press Power.
    Your TV and STB will power on or off accordingly.
If you want to reset your remote to enable the one press power function or if you'd like to reset your remote to the original factory default settings, consult your remote control user guide.
cliock this link directly to get the user manual in this codes are lisated on second page.check out your unit beside that code is listed. http://onlinehelp.verizon.net/consumer/bin/pdf/philipsrc144remotecontroluserguide.pdf ------------- this will help.please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 11, 2009
How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd?
You can probably find the code in the user guide for the RC122 or the user guide of the BDP-S3200 or you can call Sony tech support to get the code.
Dec 28, 2014 | Sony Televison & Video
Have a Phillips RC144 5302 Remote that is not working with a LG 372D Flat screen TV
Try these codes.
0004 0050 0009 0005 0227 0338 0012 0057 0080 0156
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 08, 2012 | Televison & Video
How do you get BDP-S360 to play all regions?
hi,
to make ur player region free for dvd u should have a Oneforall universal remote wich acept 4 digit code
Firs of all u have to program the remote for the purpose. procedure is as follows
Full procedure for a oneforall remote is as follows:
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until it flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDP-S360 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing. (Centre light)
3. Put the player back into standby with the Sony remote.
4. Hard reboot machine (remove power)to prevent the 24p light flashing indefinitely.
5. Next time you turn on the player it will be region free for DVD playback.
ok
Jan 22, 2011 | Sony BDPS370 BluRay Player
Progam phillips RC144 remote for verizon fios
the remotes usually to program combos ...but you may want to try the dvd ...and vcr codes ...as well
May 22, 2010 | Philips 19MDTR20/99 19 in. TV/VCR/DVD...
Do you know the sony bdp-s360 remote code?
2338 worked for my uverse remote bdp-s360
Dec 27, 2009 | Sony BDP-S360 DVD Player
Have phillips modle RC144 5302 remote for verizon
I'll tell you that guy is a **** for FREE!!!
Jun 21, 2009 | Philips Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
