Question about MicroBoards Saturn (SPS-1007-01) Burner
Where is the transaxle filler located - MicroBoards Saturn (SPS-1007-01) Burner
  • 3,741 Answers
Take off any under-covers from beneath the vehicle's engine on driver's side (and passenger if necessary).
Transmission is the big case that the driver's side wheel axle comes out of going to the wheel (CV axle = Constant velocity).
Front of vehicle look for plug slightly above 1/2 way up the case.
The drain plug is located on the side near the axle output area. Be VERY careful with the head on this as they are typically not very "tall" and if you are using a wrench, you can slip off and round off the corners, making removal difficult if not almost impossible. Luckily, I usually just change the axle seals out when I change fluid, so I end up pulling the axles and the fluid drains out into my pan.
The fill plug is located where it is to limit the amount of fluid that can be put into the case, leaving airspace.
I usually put my fill tube into the hole, then with the cap turned to the "off" position (after bottle is screwed on) I hand it up to myself at the top of the engine bay by lodging the bottle so I can reach down and grab it (I work alone). Then I twist the cap to "open" and let gravity and squeezing fill the case. You will have to change bottles after the first, be sure to put down cardboard or towels to catch the drips that WILL happen.
You may find you have to squeeze the 2nd bottle from beneath at the end, you will see the red fluid snaking through the tube. When it seems full, grab the fill plug in one hand (wipe any dirt off) and pull the fill tube, and quickly replace (screw in)plug to stop the leaking back out. At tranny shops they have a pump that they just fill the case, then pull the tube and let the excess run out into an elevated catch pan. -Ahh, to own a lift!
That's it! If you elect to pull the axles (with crowbar and elbow grease) ALWAYS change the shaft seals at the same time because they are easy to damage and losing your fluid/tranny on the road sucks! Trust me.
Posted on Sep 11, 2009
Testimonial: "Exactly what I was looking for!!."
Vacuum leaks ford freestar
leaks around the filler tube and grommet. The condition may be due to a restricted transaxle vent. ACTION: Repair the transaxle
Jul 18, 2012 | 2004 Ford Freestar
Where do you put transmission oil in on a 2003 kia spectra 5 speed transmission,1.8L?
LOOK ON FRONT SIDE OF TRANSAXLE HOUSING LOOK FOR FILLER PLUG.REMOVE FILLER PLUG.STICK FINGER IN FILLER PLUG HOLE.IF FINGER COMES OUT DRY . USE A FUNNEL ADD MORE LUBRICANT UNTIL LUBRICANT LEVEL REACHES FILLER PLUG HOLE THEN INSTALL FILLER PLUG BACK IN TRANSAXLE.
Aug 31, 2011 | 2003 Kia Spectra
Where is the transmission dipstick on 1996 cadillac deville?
The Transmission Dipstick is attached to the black cap of the Transaxle fluid filler.
It is hard to see and is located next to the radiator hose and below the air cleaner assembly on the driver's side of the engine. Remove the air cleaner assembly so you can reach the transaxle fluid cap.The assembly is attached to the vehicle by two fasteners. Simply lift up on the assembly and remove it. Turn the transaxle cap counter clockwise to remove it.
Be sure to follow the direction for checking the fluid. Park on a level ground. Keep the engine running. Apply the parking brake. With your foot on the brake, shift through all gears, pausing about 3 seconds in each range. Place your car in park and proceed to check the fluid level.
GJN
Jan 24, 2011 | 1996 Cadillac DeVille
How to check trans fluid vw 2001
  1. Park the vehicle on a level surface.
  2. Raise and safely support the vehicle such that it is level.
  3. Place a suitable drain receptacle underneath the rear of the transaxle.
  4. Remove the filler plug on the side of the transaxle, near the halfshaft flange.
  5. Note the oil level; it should be even with the lower edge of the filler hole.
  6. If the oil level is low, add the proper type and viscosity as necessary to obtain the correct oil level.
  7. Install the filler plug, and tighten it securely.
Dec 22, 2010 | 2001 Volkswagen Beetle
Where is the transmission dipstick in my manual 1.3 liter 1993 suzuki swift located and where do i fill it up?
LEVEL CHECK With Oil Level Gauge Fig. 1: Manual transaxle oil level check - with level gauge 84241046.gif
  1. Drive the vehicle to bring the transmission up to operating temperature.
  2. With the engine stopped, remove the oil level gauge front the side case of the transaxle.
  3. Check the color and smell of the oil. If it is black in color or smells burnt, further transmission service is needed.
  4. Wipe off oil level gauge with clean cloth.
  5. Fit the oil level gauge to the transaxle side case so that the threads rest on top of the case.
  6. Remove the gauge and check oil level. The level should be between FULL and LOW level line.
  7. If the level is below LOW mark, add oil until the proper level is reached.
With Oil Level/Filler Plug
  2. Raise and support the vehicle safely.
  3. Remove the transaxle oil level/filler plug.
  4. Check the color and smell of the oil. If it is black in color or smells burnt, further transmission service is needed.
  5. Transaxle oil level should be even with the bottom of the plug hole. If oil level is low, adjust oil level accordingly.
  6. Install transaxle oil level/filler plug and tighten to 40 ft. lbs. (54 Nm).
  7. Lower the vehicle.
Oct 17, 2010 | 1993 Suzuki Swift
Where is the back-up light switch located? I have no back-no lights.
prev.gif next.gif Back-up Light Switch REMOVAL & INSTALLATION Cabriolet On the Cabriolet, the back-up light switch is mounted in one of three positions: screwed into the front face of the transaxle beside the oil filler plug, screwed into the top of the transaxle case to the left of the shift linkage, or mounted as a microswitch on top of the transaxle with a lever that is activated by the external shift linkage. Fox The Fox back-up light switch is screwed into the rear of the transaxle housing. Simply unscrew it from the housing to remove or replace. 1990 — 92 Golf and Jetta The back-up light switch includes the fifth gear switch used by the up-shift light. It is mounted to the selector shaft housing on top of the transaxle, secured with 2 bolts and sealed with an O-ring.
  1. Make sure the transaxle is in neutral.
  2. Disconnect the wiring and remove the bolts to remove the switch. Be careful not to loose the O-ring or bolt bushings.
  3. Fit the bushings and O-ring onto the switch and install it onto the transaxle. Tighten the bolts to 7 ft. lbs. (10 Nm) and connect the wiring.
1995 — 99 Cabrio, 1993–99 Golf and Jetta
  1. Remove the negative battery cable.
  2. Remove the electrical connector.
  3. Unscrew the switch using a wrench to break it loose.
  4. Remove the back up light switch from the housing.
  5. Keep the O-ring. To install:
  6. Installation is the reverse of removal.
Aug 17, 2010 | 1995 Volkswagen Jetta
Cannot locate transmission filler plug on 2007 suzuki forenza
Raise vehicle and support with safety latches/jackstands, etc. The transaxle fill plug is located above the location where the passenger c.v. halfshaft enters into the transaxle. You'll need to purchase a 5/8" square drive in order to remove and re-install it.
Feb 04, 2010 | 2007 Suzuki Forenza Sedan
Gear OIL in Daewoo Leganza SX manual transmission
CHECKING FLUID LEVEL
1. With the vehicle on a level surface and the fluid in the transaxle cold, remove the filler plug and check the fluid level. The fluid should come to the bottom edge of the plug hole.
2. If the level is low, add SAE 80 manual transaxle fluid through the filler plug hole until the fluid begins to run out.
3. Reinstall the filler plug and tighten it securely. The speed gears and the synchronizer parts on this vehicle receive lubrication through specific passages in the mainshaft. It takes 1.8 liters (1.90 quarts) to fill the transaxle completely.
its located next to drive shaft some on left hand side others on right hand side depending what gearbox.
May 30, 2009 | 2000 Daewoo Leganza
Does anyone have a picture of the transaxle oil fill plug for its location on a 1997 Lantra manual gearbox
hi
remove the speed senser from gear box and put trans oil in . this is only one way if u dont have filler plug
Apr 06, 2009 | 1997 Hyundai Elantra
Need to locate access panel to replace HeaterCore 1990 Buick Skyl
  1. Disconnect the negative battery cable.
  2. Drain and recycle the engine coolant.
  3. Raise and safely support the front of the vehicle.
  4. If necessary, remove the rear lateral transaxle strut mount.
  5. Detach the drain tube, then disconnect the heater hoses from the core tubes.
  6. Carefully lower the vehicle.
  7. Remove the console if equipped.
  8. Unfasten and remove the sound insulators, console extensions and/or steering column filler, as required.
0900c152800a93fc.jpgFig. 1: Unfasten the sound insulator retaining bolts ... 0900c152800a93fd.jpgFig. 2: ... then remove the sound insulator
  1. On some models it may be necessary to remove the steering column opening filler.
  2. Remove the floor or console outlet ductwork and hoses.
  3. Remove the heater core access cover.
0900c152800a93fe.jpgFig. 3: Remove the heater core access cover
  1. Unfasten the heater core mounting clamps/bolts, then extract the heater core from the vehicle.
0900c152800a93ff.jpgFig. 4: Unfasten the heater core retaining bolts; most later models are secured with clamps 0900c152800a9400.jpgFig. 5: Remove the heater core from the vehicleTo install:
  1. Install the heater core, then secure using the clamps/bolts.
  2. Fasten the heater core cover.
  3. Connect the outlet hoses and ducts.
  4. Install the sound insulators, console extensions and/or steering column filler.
  5. Raise and safely support the vehicle.
  6. Install the drain tube and connect the heater hoses to the core tubes.
  7. If removed, install the rear lateral transaxle strut mount, if removed.
  8. Carefully lower the vehicle.
  9. Connect the negative battery cable.
  10. Fill cooling system and check for leaks. Start the engine and allow to come to normal operating temperature. Recheck for leaks and check coolant
Dec 06, 2008 | 1990 Buick Skylark
MicroBoards Saturn (SPS-1007-01) Burner Logo
98 people viewed this question
Top MicroBoards Computers & Internet Experts
Rick Moore
Rick Moore
 Grubhead
Grubhead
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
