Question about Nakajima AE-710 Typewriter
How do you clear the margins and reset them? - Nakajima AE-710 Typewriter
  • Nakajima Master
  • 3,594 Answers
Return to the L. margin, press and release the mar rel key, backspace to the desired location press the mar left key, the R. margin is pretty much the same.
DickyO
Posted on Sep 11, 2009
How to clear history of tabs and margins to start over on the Brother GX-6750
Unfortunately, I don't think you can reset all of the margins and tabs at once. To reset a specific margin, move to that margin and then press ALT and the 6 key simultaneously. (That's the Margin Release.) If you are resetting the left margin, press the backspace (or space) key until you reach the new margin location. Then press Alt + 7 (L Margin) to set the new margin. For the right margin, press space (or backspace) until you reach the new margin location. Now, press Alt + 8 to set the new right margin location.
You can clear all of the tabs by pressing and holding Alt + 0 (tab clear) for over half a second.
The manual for the GX-6750 is available from Brother on the product support site: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=GX6750 . Click on the Manuals & Documents tab. The direct link to the manual (in English) is http://www.brother-usa.com/VirData/Content/en-US%5CTypewriters%5CConsumer%5CUsersManual%5CUM_AX325_GX_6750_EN_5674.PDF / The procedure to set the margins is on page 2. The procedure to set the tabs is on page 5.
I hope this helps.
Apr 26, 2016 | Brother Office Equipment & Supplies
How do I clear and set new margins on a Swintec 1000?
Go to the margin, press but don't hold the MAR RE: key space or backspace to the desired location, press the margin key you are trying to set.
DickyO
Aug 24, 2015 | Swintec Office Equipment & Supplies
How to clear left and right margins?
Go to the margin, press mar rel key space or backspace to desired location press L. or R. margin key to reset it.
DickyO
Aug 17, 2010 | IBM Wheelwriter 30 Typewriter
How do you clear a tab someone preset. when I get to the far right of page and hit return it will on return to a tab. How do I clear all the preset margins or tabs.?? thanks
To clear margins, you have to hit the return button to find the left margin, then hit margin release and back space to move the margin left or spacebar to move to the right, then hit left margin button to set the new position. Right margin now. Hold spacebar down and find right margin position, hit margin rease and either spacebar to the right or backspace to the left to the new margin position then hit right margin button to set the new position. Tabs now. hit the tab key, when it goes to the first set tab, hit the tab clear key, then hit the tab key again, then tab clear again etc.
Dec 29, 2009 | Swintec 7040 Typewriter
How to clear margin when in use
Left margin...use the code key (colored)
Move the carriage to where you want the margin, use margin release if you have to go beyond the present margin, and use the margin set key to set.
You have to reset a margin. can't just clear one.
Can set margins at each end of the typing line, then you will have no margins.
Hope this helps!!!
Dec 16, 2009 | Smith Corona Wordsmith 100 Typewriter
IBM Wheelwriter 30 won't let us clear the left margin
If the carrier (print head) goes to the left when you turn the T/W on then try this.
Return to the L. margin, press mar rel key, backspace to the location that you want the margin, press L. mar key the wheel should spin and reset the margin.
DickyO
Oct 16, 2008 | IBM Wheelwriter 30 Typewriter
Margins will not reset
Return to the stopping point, press and release the mar. rel. key backspace to the left then press L. mar. key.
To clear tabs tab all the way yo the rt. press & hold tab clear touch ret all tabs should clear.
Hope this is helpful
DickyO
Jul 11, 2008 | Nakajima AE-740 Typewriter
Left margin
It may be that the rail is sticky, put a little light oil (sewing machine oil will work) on a cloth and wipe the rail end to end with it then work the carrier left to right with the return and tab keys this should free it up.
Jun 03, 2008 | Swintec 7040 Typewriter
Margin locked
check that there is nothing dropped into the typewriter that may be blocking the carrier try turning the machine off and moving the carrier by hand to the right side,if it moves ok then turn it back on space the place it stops , touch the MR (margin release button) then try spacing further to the right nad reset the right margin.
Jan 28, 2008 | Swintec 7040 Typewriter
Margin clearing and resetting
You cannot "clear" the margins. You have a left margin and right margin. They MUST be set somewhere even if they are set at the extreme left and right of the carriage. This part is IMPORTANT!!! Some functions (like right margin or margin release) may be written in a different color or shade. If they are, you must hold down the CODE or FUNCTION key while touching that function. In any case, the CODE key or similar will be the same color as the function you are trying to access. Get the printer where you want the margin to be. If you want the left margin set to the left of the current margin you will have use the MARGIN RELEASE key first. This may be labeled MREL or MAR REL or something similar. Backspace to where you want the margin to be then press the LMAR or LEFT MARGIN key. That will set the left margin at that point. Repeat the process for the right margin. Hope that helps Ed
May 26, 2007 | Nakajima AE-830 Typewriter
Nakajima AE-710 Typewriter Logo
113 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Ron Dufek
Ron Dufek
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
