Question about Edimax BR-6216Mg Wireless Router (BR6216MG)
Problem with Local area connection
When try connecting the new router to my computer via ADSL modem I can not get connection and getting alarm of local area connection unplug.
All ethernet cables were test and work fine.
When using only the ADSL I have intenet connection,please advice.
  • mkadishi Dec 12, 2007
    The router is new and I followed the quick setup wizard the router had been succesfully connected to the internet for 2-3 hours then I noticed the power led is switch OFF and after few sec ON again,
    I suspect the PSU 12v 1000mA is not stable but when the router is not connected to the computer the power led is ON without issue.
    THe symptom appear only when the router is connected to the computer.
    please advice.
  • mkadishi Dec 22, 2007
    The router found as bad one,
    I got new one and all works fine since.
    Thanks.
  • 556 Answers
In general the Wan port of the router gets connected to the ADSL modem where the computer used to connect and the computer connects to the switch portion of the router which often has 4 ports. The router has configuration options that must be set to comply with your internet service providers (ISPs) requirements. These can often be found on his support web site. If you can provide the link to the website I can assist with the search. Otherwise I will need the name of the ISP. If this ISP is cable related like Road Runner I will need the associated cable provider. I will also may need to know the country, city and state in which you are located as some ISPs have geographic differences in equipment. Depending on what that information determines I may also need to know the Manufacturer and Model of the DSL Modem -- probably the box your computer plugs into when it is working. It would also be helpful to know if you got the router used or new. Used routers may have been configured by their previous owner and require additional changes to new routers with factory default settings.
Lastly as a wild guess. There are some ISPs that extract address information (MAC Address) from the attached network card into the units they send you to attach to the phone line or cable. Should you happen to be with such a company they often state turn on the modem before the router so it recognizes the change. You may want to try turning off the modem attaching the router without power then turning on the modem wait a minute and power on the router -- if your ISP requires default settings for your router and it was new this may work. As far as the alarm for unplugged cables -- do the cables have the clip portion on the ends and are they securely established in the ports. Are the contact points on the cables free of dust and dirt? Especially if the router is used have you tried a different port for the computer side connection? In case of the computer end have you tried multiple computers -- possibly a friend's if you do not have more than one.
There is a strong likelyhood this simple solution will not work. All of the above information may lead to the determination that we must enter a static IP address into the router, maybe we need to provide for PPPoE login for the router, maybe we need to configure the switch to allow the router to perform the PPPoE login, and several other such items. This is probably not a one reply solution.
Posted on Dec 10, 2007
  • david Dec 10, 2007
    Correction
    In the last case it is configure the modem (not the switch) to allow the router to perform the PPPoE login.
  • david Dec 12, 2007
    I am sorry but my first impression was that this was possibly a configuration error somewhere in the system. I now get the impression that this is a hardware issue - outside my area of expertise. In the area of a guess, if you have more ethernet lan ports than required on the router have you tried to plug the computer into one if the other ports to see if the problem goes away? If it does and you do not need the bad port this may be a workaround for the issue. WARNING: Running even in this state with possibly faulty hardware could further damage the equipment itself as well as any equipment attached to it, so continual operation in this state may not be desirable. However it may assist in isolating the problem to a portion of the device before taking it to the repair shop or the store for a replacement. The problem could also be on the network adapter in the computer -- if AND ONLY IF you are capable swapping the network adapter and testing could determine that the problem is not with the router but with the computer's network adapter. another method if doing this is to either test your computer at a friend's house and test his computer at your house (both will change the at least one side of the connection) -- if it happens at his house it is the equipment you took there -- if it happens at your house it is the equipment you left behind. However with the unpredictability of some computer problems it may remain unclear with everything working at both houses. Also there are varying test qualities with cables and intermittent connections caused by movement or use could go undetected by a simple continuity tester.
How to get it connected to the internet
phone a local internet service provider tell them you wish to connect to the internet they will then advise you that you need a modem. Either a cable modem , ADSL modem or a Radio Modem depends on if Broadband Radio available or needed. Then the router is connected either via the modem or has a built in modem in it.
Tell them what make model number of router you have and they should advise you on how to connect it to their internet network.
Oct 10, 2015 | Computers & Internet
Wireless Router showing as connected, but cannot access Internet.
You have _THREE_ separate network connections to check:
1. your router, through your ADSL modem, to your ISP;
2. your computer, through an Ethernet cable, to your router;
3. your computer, through its wireless adapter, to the wireless adapter in your router.
So:
1. Connect the Ethernet cable from your laptop directly to your ADSL modem, bypassing the router.
Turn the router off.
Restart the modem.
Restart the computer.
Click Start
Click Run
Enter CMD and press ENTER
Enter IPCONFIG and press ENTER
You should get output like:
Ethernet adapter Local Area Connection:
* IP Address. . . . . . . . . . . . : 123.456.789.249
* Default Gateway . . . . . . . . . : 123.456.789.1
* Subnet Mask . . . . . . . . . . . : 255.255.255.0
Enter PING 123.456.789.1 and press ENTER
If PING does not respond, then telephone your ISP, and get them to trouble-shoot your connection.
2. Turn off the ADSL modem.
Connect the Ethernet cable from your laptop to one of the LAN ports on the router.
Turn the router on.
Restart your computer.
Click Start
Click Run
* IP Address. . . . . . . . . . . . : 192.168.0.100
* Default Gateway . . . . . . . . . : 192.168.0.1
Enter PING 192.168.0.1 and press ENTER
If PING does not respond, then your router is not working.
If PING does respond, connect another Ethernet cable from the WAN port on the router to the ADSL modem.
Turn the modem on, and wait until the flashing-lights on the modem, and on the router, settle-down to a steady pattern.
Type PING WWW.GOOGLE.COM and press ENTER.
If PING responds, then everything is fine.
3. If you fix #1 and #2, above, then your wireless adapter should work.
Apr 02, 2010 | Computers & Internet
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
Linksys speed cut off
First, are you connected via Ethernet cable or are you linking via Wi-Fi? If Wi-Fi the speed is alway slower (up to 54 Mps) If connected by Ethernet, your connection speed should read 100 Mbps. Once you have determined the connection mode and speed.unplug the wireless router and connect the computer directly to the modem. Now test the speed and see if the speed lag is still ther. If not, you have a routing /networking issue but, it it is still the same speed, it could very well be heavy traffic ( a lot of people drawing from the same local area signal., usually at specific times of the day).
Nov 24, 2009 | Linksys Wireless-G WRT54GL Router
Router not connecting with adsl modem wirelessly
re-set it and re-configure it ur router then you get it
Mar 12, 2009 | Computers & Internet
Local area network cannot repair itself
are you using a router or do you have a dirrect connection to the dsl modem?
have you tryed unhooking modem and restarting it and the pc?
also does your modem have an acess page such as 192.168.0.1?
Feb 16, 2009 | SMC Barricade g SMCWBR14-G (662698582192)...
Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
so your trying to use a dsl router as just a router -dsl with dialup?
Aug 06, 2008 | NetGear Computers & Internet
Internet connection
Connect a computer to one of the lan ports 1-4.
Connect the adsl modem to "internet" or "wan" port of hub.
Open the hub's configuration page in your browser, usually this is http://192.168.1.1 Under Setup->Basic Setup, set the configuration for "Internet Connection Type " to "Automatic Configuration - DHCP". Under Network Setup, enable the hub's internal DHCP server so your lan hosts can get their ip's from the hub. Each local computer should have DHCP enabled. Your adsl modem must support DHCP for this to work, some do not. If it still doesnt work, try setting "PPPoE" instead of DHCP.
May 14, 2008 | Linksys Wireless-G WRT54GL Router
I can not get on line
When you plug in the network cable, ensure it is plugged in correctly to the network card and into one of the router's ports at the other end. The LINK light should light up at either end (computer end and a tthe router) and flash when data is being sent or received. Then on your computer, (for Win2000/XP) go t Start, Settings, Network connections, "Local Area connection" for your card, then click on "Properties" then scroll and double click ''internet protocol' then select obtain ip address automatically. this will assign your computer with an ip address given from the adsl modem. all other settings will then assign automatically as well which should give you access to the internet thereafter. What you could also try is from one of your working wireless computers / laptop, see what IP address and gateway addresses have been assigned by the DHCP host (automatic IP address assigner), to helpyou work out where the address is coming from, it should be coming from the adsl modem. check your address by going to Start, settings, network connections, local area connection, then click on the support tab.
Apr 02, 2008 | D-Link Wireless
No connection
Is your physical connection right???
the WAN port should be connected to your modem, and the LAN1 should be connected to your pc.....
if right, but still doesn't connect....
check if the lights of your router is working
the POWER should have a solid light,
the STATUS, WAN, LAN 0r WLAN should be blinking...
What kind of connection do you have?
is your modem automatically detects your password...?
or you manually type your password to connect to the internet...?
Jan 17, 2008 | D-Link DI-704P Router
Edimax BR-6216Mg Wireless Router (BR6216MG) Logo
161 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Rommel Balcita
Michael Galve
Michael Galve
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
