Question about Car Audio & Video
I have a Dodge Coronet Car 1958 and have no idea where the FUSE BOX is located. also the turn Signals Unit has stopped flashing at the Off side Rear Indicater and I can not find the UNIT for that. Can anyone help me ? LARRY
    Problem Solver:
  • 5 Answers
Dodge fuse blocks are usually upside down at the base of the dashboard on the driver side, very near the flasher that would drive the rear turn signals, there are two, one drives the turn signal and one drives the Emergency flasher. With any flasher working, you can feel which one it is, you can find it by the sound it makes.
Posted on Sep 11, 2009
Testimonial: "Thanks for your prompt reply. I will look where you suggest and get back to you . Many thanks Larry"
Why did my 1995 dodge neon drivers side high and low beams stop working
have you checked the fusebox drivers side lower adsh as there is probably a fuse for each side of vehicle lights ets list of fuse location should be on the lid/cover.just a thought you have turned the light switch to 'parking light' position , there is also a fuse box in engine compartment worth checking keep me posted if you wish
May 12, 2014 | 1995 Dodge Neon
1991 dodge spirit turn signals don't flash. Do I need a new fuse? Where is box?
The bulb that shows other drivers the turn might need to be replaced.
Nov 27, 2012 | 1991 Dodge Spirit
I have a 2006 dodge ram 1500, my right front blinker does not flash, the back right flashes really fast. I checked the front right bulb and it is not burnt out and I cant find a fuse or relay to check.
The fuse for the turn signals is located in the interior fuse panel, usually located under the dash on the drivers side although it may be behind a panel on the side of the dash on the drivers side that you can access when the door is open. The flasher relay is located on or near that fuse panel as well. There is only 1 fuse for the turn signals so if you have some of them but not all of them it's not the fuse. It may still be the relay but I doubt it. That bulb may not look burned but it most likely is. that fast blinking on the right rear is an indicator that the front bulb is burned or not functioning. It is an indicator dodge built into there lighting systems. Replace the bulb, if that doesn't resolve the problem start check the wiring and look for a grounded wire.
May 24, 2011 | Dodge Ram 1500 Cars & Trucks
Both my right & left turn signals aren't working but hazards are
If you can locate the hazrd flasher unit under the dash on the drivers side, the turn flasher unit should be right beside it and looks the same. Unplug and switch the 2 flashers and see if the turn signals work. The flasher unit is a silver and round. they are usually close to the stering colum. Let me know if that helps.
Mar 27, 2011 | Dodge Durango Cars & Trucks
Emergency flashers and turn signals stop operating
The engine compartment fuse box locations - 1995-96 Continental 93146g35.gif
Sep 24, 2010 | 1995 Lincoln Town Car
I HAVE JUST BROUGHT A DODGE CORONET CAR 1958 AND CAN NOT FIND THE FUSE BOX OR THE FLASHER UNIT. CAN YOU HELP ? LARRY
Larry that car is not new.
When that car was made it was only about a month after they invented the wheel.
Does it have the screw in fuses? If yes, use a coin between the contact.
Flashers didn't appear until the 60's as streakers.
Lot of luck with that piece of **** it was junk in the 50's.
Sep 10, 2009 | Gb Electrical 1 30 Amp Ground Fault...
Turn signals and hazard don't work
Next best guess is the flasher unit has failed, this could be your little blue box, pick up a replacement at any auto parts store and replace it.
Apr 15, 2009 | 2005 Dodge Caravan
Rear Turn siganls flash fast, both front signals will not flash
flasher relay(in fuse block)weak.also check for other burned out bulbs.
Dec 13, 2008 | 1998 Oldsmobile Intrigue
My hazard lights and turn signals stopped flashing
i bet you have a bad multi function switch or turn sig switch. good luck
Oct 25, 2008 | 2006 Dodge Ram 1500
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
