Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Water supply very slow to the ice maker.
How do I disconnect the hose to
a) check to see if it is clogged up and
b) remove any air bubble
  • 93 Answers
Is the water slow coming out of the water dispenser? Your fridge should have the same water pressure as any sink in your house. Most of the time low water supply is from thw water valve in your basement or under the sink or wherever your is hooked up. Most people use piercing valves and they always plug up
Posted on Sep 11, 2009
Ice machince is going max freeze cycle shut down
1. Possible cause. Water leak. Check purge valve, water curtain, sump, sump hose.
2. Air filters clogged. Clean air filters.
3. Dirty condenser. Clean condenser.
4. Restricted location, intake air to hot. Have machine moved.
5. Ice thickness sensor dirty or disconnected. Check ice thickness sensor probe.
6. Water distributor dirty. Remove and clean water distributor.
7. Inlet water valve leaks through during freeze cycle. Check water inlet valve.
8. Connected to hot water. Check for bleed through from missing check valve in building water supply.
9. Incomplete harvest. Check harvest system.
10.High pressure cut out opened. Check fan motor pressure control, check fan motor, check controller using test mode.
11. Fan motor pressure control open. Check fan pressure control.
12. Fan motor not turning. Check fan motor, check fan blade,check controller using test mode.
13.Water pump not pumping. Check pump motor,check controller using test mode.
14. Pump hose disconnected. Check hose.
15. Compressor not operating. check compressor contactor, check controller using test mode.
Check compressor start components, check PTCR resistance and temperature, check compressor voltage, check compressor windings.
16. Low refrigerant charge. Add some refrigerant and restart unit. If cycle time imporves, look for a leak.
17. Hot gas valve leaks through during freeze. Check hot gas valve for hot outlet during freeze.
18. Thermostatic expansion valve bulb loose. Check bulb.
19. Thermostatic expansion valve producing very low or high superheat. Check evaporator superheat, Change TXV if incorrect.
20. Compressor inefficent. Check compressor amp draw, if low and all else is correcy, change compressor.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
LSC27926ST REFRIG/freezer. Ice maker is leaking water that freezes on items in freezer, ice is messed up and had to unclog ice maker. Still a logjam of ice around ice maker. has been churning out ice...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
Sep 10, 2011 | LG LFX25960ST Stainless Steel French Door...
Ice tray filler tube freezes up and clogs up so no water goes into tray
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
May 22, 2010 | Amana SXD524VW Side by Side Refrigerator
The water supply tube in the back of the refrig pops off when the refrig attempts to make ice. There is no clog in the supply line. How do I check the attachment that is attached to the back of the...
if you think it's clogged it's probbaly iced up,use a hair dryer and melt it out,see if you can put a hose clamp around the hose to hold it in place,does any water make it into the ice maker?see if you can stick a straw oonto the piece the tube slides onto and see if you can blow through it to see if it's clogged or it's just the water pressure blowing the line off,might just need to be attached better
Jan 27, 2010 | Amana ABB1927DE Bottom Freezer...
Ice maker does not produce ice, it was clogged with ice. so i fixed that . the tube coming down from the top was what was clogged frozen . red light is flashing twice repeatadly. need info to fix. thank...
Jan 27, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE side by side. When ice maker tries to refill water is going everywhere except in the ice tray. Removed ice maker but saw no problem with it. Any hints of what to look for?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Dec 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water wont go all the way into the ice maker
Or
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Oct 08, 2009 | Kenmore Refrigerators
Kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Apr 08, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
Ice amker and water spickett is no longer working
Hollow ice cubes are the result of poor water flow to the ice maker. I know you already have experienced flow issur since you mentioned poor water dispenser flow. You apparently have a filter clogged, a house supply valve clogged or lastly a clogged water solonoid valve. The filter is self explanitory. You would replace the filter. The house supply valve is next most likely, to test it you would need to remove the supply line at the rear of the refrigerator after turning supply off the turn supply on to check flow. If the flow is STRONG then next most likely is a clogged solonoid valve. To test it you would, with supply connected and turned on, need to locate the plastic tube that goes to the water dispenser reservoir in the refrigerator section. Disconnect the tube at the solonoid valve and place glass or pitcher at solonoid port while someone presses the diapenser lever. If you have poor flow then but had good supply flow, the valve must be bad.
Nov 21, 2007 | Jenn-Air JBR2088HES Stainless Steel Bottom...
Whirlpool ice maker
Hi Chubbo,
 When you say you checked the Valve, did you check the Supply valve that feeds water to the fridge, or the Solenouid valve that usually casues this problem.  Unplug your Fridge and roll it away from the wall.  Remove the  rear access panel  and trace the water supply tubing to the solenoid valve. Lots of time the valve is bad.  You  can get a replacement  Solenoid.  at any Appliance part store, or online at www.repairclinic.com
If you did check that. You can get a coupling that will adapt from the water supply directly to the line coming from the solenouid to pressure up and see if you actually have a flow problem between the solenoid valve and ice tray.
Hope this is helpful to you. Good Day
Oct 18, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
80 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
