Question about HP LaserJet 4350 Printer
I can not clear the error (49.4C18) on the 4350 printer. Is there a way to fix it?
  • Buddy Mcsparrin May 11, 2010
    Hello, The error is caused by corrupted firmware on your printer. We have a step by step resolution to this error posted on our web site at: www.ccl-la.com Click on printer repair pages, then click on the HP section. I hope this helps, if so please rate my solution. Buddy Corporate Computer www.ccl-la.com
    President:
  • 1,653 Answers
This error can have a number of causes. Sometimes, a corrupt file, or pdl string from certain applications can cause this. It could be something on the formatter. You could try to take out any added EIO cards, hard disks, or font or memory Dimms and power on to see if it clears. If so, then try to add them again one at a time to see if any cause an issue. If it does occur; make sure to clear the offending print job from the print queue before going any further. If any Dimms or cards, etc. are the cause, then replacing them should help. If you can get it to clear, going into the CONFIGURE DEVICE / RESET MENU and resetting to factory defaults may help, or in some more extreme cases an NVRAM initialization, but it resets the page counts and serial numbers and other system settings. An NVRAM INIT is done like a cold reset except when SELECT LANGUAGE appears scroll to NVRAM INIT. It could also be an issue with the original JetDirect embedded print server.
Posted on Sep 11, 2009
jaylex
  • 417 Answers
SOURCE: HP 4350 printer
EIO is the port for the network card on the back of the machine turn off machine remove card from EIO2 and install into EIO1 turn machine on and see what happens. If this does not work then open the formatter casing and remove the memory chips (OF COURSE WHEN THE MACHINE IS OFF) after removingone turn machine on and see if it boots up.
The 49 error is normally a software issue with the machine and it has locked within the network area or the memory.
Hope this helps you and please rate me
Cheers J
Posted on Dec 31, 2007
SOURCE: hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Posted on May 28, 2008
xcanox
  • 32 Answers
SOURCE: 49 4C02 error
Well I was having the same problem. I cleaned out the queue by canceling the job that it was having the problem with. Turns out the data being sent to the printer was corrupt in this case.
Posted on May 30, 2008
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
seeker5211
  • 1089 Answers
SOURCE: LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
Posted on Jun 13, 2010
Printer error Code 6000.
Fix your printer
Another site says you can clear the error message by turning off the printer, unplug it from the wall, wait 25 minutes, plug it back into the wall, turn it on. This is in reference to a Canon printer. If both the Fix your printer and my typed tip fails, you can contact cannon:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
Jun 02, 2017 | The Office Equipment & Supplies
GIVE THE MASSAGE ERROR E000000 XEROX CANON IMAGERUNNER 2520 MACHINE
Go through the following to clear the error: CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power.
If this does not fix it check connection of the Connectors (Thermistor Connector and AC Connector).
If this does not fix it replace the Fixing Main Thermistor (Film Unit).
If this does not fix it replace the Fixing Assembly.
If this does not fix it replace the DC Controller PCB
Best regards,
Marius
P.S. if you are not in US the part number for EU region is FM4-8445-000
Dec 01, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Canon iR6800C printer error code E000002-0001 pls fix this error code on photo coppier machin
Hi. You have to clear that error from service mode
Try to clear that error from service mode
press additional function
2 and 8 together
select copier
select function
select clear
select ERR
select ok. Unplug of the machine for 5 second and then turn it back on
try to make some copies, if problem persists fixing heater is damaged and need to be replaced
Mar 28, 2015 | Canon Office Equipment & Supplies
Error code E000 0001
Dear
Its Fixing temperature abnormal rise.
1.Go through the following to clear the error: CLEAR >
power.
2.Check connection of the Connectors (Thermistor Connector
and AC Connector).
3.Replace the Fixing Main Thermistor (Film Unit).
4.Replace the Fixing Assembly.
5.Replace the DC Controller PCB.
Thanks.
Feb 02, 2015 | Office Equipment & Supplies
I can't print in my Canon Pixma IP1980... service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix...
service error 5201. cancel printing and turn the printer off and then on again. if doesn't clear the error, see the printer manual for more detail. how can i fix this?
Dec 08, 2010 | Canon Office Equipment & Supplies
Error sc 547
Found this from:
http://slayo.com/ricoh-cl4000dn-error-code-sc542.html
Ricoh CL4000DN Error Code SC542
Turns out error SC542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won’t come ready until the prior error condition is cleared.
A few phone calls with our local Ricoh service rep, and he admitted that the printer might trip this error in a power brownout.
The printer was less than 30 days old and the error was caused by the brownout or the fuser failed. I kept calling the Ricoh rep, and they finally gave me the magic keystrokes over the phone.
I did the magic keystrokes, cleared the error code, and the printer worked fine. It’s been working great for a year now.
I hope someone else who has this problem finds this page and is able to fix the problem also. I didn’t find any help on the net when I searched.
The Fix In order to clear error SC542, you must perform procedure 5810.
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
The error code is now cleared.
Hope this helps!
WizardRepair
Jul 17, 2009 | Ricoh CL4000DN Laser Printer
How do I fix error SC552 on Ricoh 2238C?
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared.
The magic keystrokes, clear the error code:
The Fix
Press Enter
Press Enter
Press Enter
Power off and on.
Oct 04, 2008 | Ricoh Office Equipment & Supplies
Fix system error
Please click on the below link or copy the URL and paste it in your web browser. Follow the steps..
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:93:0:0&docid=ENUS547
OR
If you are getting any type of 'CLEAR SYSTEM ERROR' on the LCD screen of the printer, please follow these steps:
1) Remove the power cable for 2 minutes and the USB cable from behind the printer.
2) Press and hold down the stop clear button and reconnect the power cable back to printer.
3) The printer LCD screen should clear the memory error.
4) If the same error message persist on the LCD screen, please follow the instructions below.
5) Unplug the power cable for 2 minutes and USB cables from behind the printer and open the printer cover and remove both ink carts.
6) Repeat step 2 and Install both cartridges then the screen will display Cartridge's clean, press start.
Thank you........
Sep 28, 2008 | Lexmark X63 InkJet Printer
HP LaserJet 4350 Printer Logo
807 people viewed this question
Seeker5211
Seeker5211
