Question about Acer Aspire 3610 Notebook
Ntldr is missing - Acer Aspire 3610 Notebook
    President:
  • 1,179 Answers
Try to do a Windows repair. To do this you'd place the Windows install dvd in the drive and then reboot making sure that your boot from cd/dvd drive is enabled. When it starts booting it will give you an option of installing or repairing. Use the repair feature and it should load any missing files. If this fails then the easiest solution is to reinstall. Hope this helps.
Posted on Sep 11, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 202 Answers
Re-isntall the Operating system (Windows) it a file taht is missing, if it is winXP, you can use the second repair console so that you don;t loose your files. and if you don't need the doc, the you can format. good luck
  • Abdulmajeed Yusuf
    Abdulmajeed Yusuf Sep 11, 2009
    re-isntall the Operating system (Windows) it a file taht is missing, if it is winXP, you can use the second repair console so that you don;t loose your files. and if you don't need the doc, the you can format. good luck
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
NTLDR MISSING AND WANT GO TO WINDOWS
MISSING NTLDR FILE
To repair missing NTLDR or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Sep 16, 2012 | HP Pavilion dv1000 Notebook
17HEWLET-PACKARD NTLDR IS MISSING
See the following web site for help on fixing this problem or alternatively, download a copy of Hiren's Boot CD and burn this CD image file (ISO) to a blank CD, then boot your computer from the CD and take the option on the boot menu to Fix NTLDR is Missing.
Jan 12, 2012 | Compaq Computers & Internet
Ntldr is missing in intel pentium3
Dear samethlida03 NTLDR is  a key boot file in your operating system.without ntldr the system will not boot fore more information how to fix this issue please visit  http://www.quickonlinetips.com/archives/2005/12/ntldr-is-missing-press-any-key-to-restart/ this link.
Thanks
Jun 19, 2011 | IBM NetVista Intel Pentium 3 1GHz / 256MB...
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
NTLDR is missing. Say's to restart, just goes back
folow this link
http://support.microsoft.com/kb/320397
Apr 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
NTLDR missing
I can get into the Boot First Screen but can't seem to change anything within it... These screens seems to be selectively responsive to my key presses.... I can get the bios screen up, boot order screen up but not necessarily do anything within them... e.g. I can't restart the pc using ctrl alt del when the missing NTLDR message appears.... also I have put an XP disc in and it says to press any key to BOOT from CD .... I Do so but obviously it doesn't recognise it so it gives me the missing NTLDR message again! :(
May 24, 2008 | Microsoft Windows XP Professional With...
NTLDR is missing. Press CTRL-ALT-DEL to restart
NTLDR MISSING PRESS CTRL+ALT+DEL TO SESTART. WEN I DO THEN WINDOW WITH ALL THE SET UP COMES. PLEASE HELP!!1
Apr 24, 2008 | Compaq Evo D500 PC Desktop
Ntldr
First check your bios & make sure it see's your hard drive & it's setup correctly. If it is there could can be other reasons for the missing NTLDR.
Suggest you take you Windows CD and boot to it. If your CD does not boot. Re-start the PC & start pressing the F8 key every two seconds. This will bring up a boot menue. Choose your cdrom drive.
Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy these two files to you Hd. copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Replace the drive letter listed above for your cdrom's drive letter.
Once copy has been complete re-boot your Pc.
If you still get missing NTLDR. Do a complete reinstall of windows. Your personal data should stay intact.
Please post back if this has not fixed missing NTLDR, there are more fix's that can be applied. I only listed the most common.
Feb 12, 2008 | AOpen Motherboards: AX4SG-UN (AAX4SGUN)
Acer Aspire 3610 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
