Question about Canon PIXMA iP2200 InkJet Photo Printer
Error code 5202
My printer Canon iP2200 cannot print, and have a message "error 5202. can anyone explain that. and how to solve this problem
  • 3,741 Answers
Its a service error.that printer needs servicing or any of the internal part of the printer is got loose or moved from its actual position.try this instruction if this does not helps then printer needs to be serviced by a locaL Printer servicing /reparing store 1: Remove the Cartridge
2: Unplug the AC Power Cord
3: Close Front access panel, Hold down the RESUME / RESET button and plug in the AC power cord
4: Release RESUME / RESET after plugging in the AC Power cord.
5: Press the RESUME / RESET once within 5 seconds and release the RESUME / RESET.
6: Press and HOLD RESUME / RESET for two seconds or more and release it.
7: Press and HOLD RESUME / RESET for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Posted on Sep 11, 2009
Testimonial: "It's work for me. Thank's for your advice"
CANON PIXMA IP2200 DOES NOT FEED PAPER
Paper not feeding into Canon Pixma MP210 printer
Several suggestions here include printing a heavy card instead of regular paper, or turning the printer upside down to remove any object like a key stuck in the printer.
Dec 20, 2017 | Canon PIXMA iP2200 InkJet Photo Printer
Tip
Canon Service Error 5202
Service Error 5202 solution for ip1800 / ip1900<br /> <br /> Steps: <br /> 1. turn-on printer, still blinking and a error message on screen, open cover. <br /> 2. While printer cover is open, unplug the power cord at the back. Of course it <br /> turns off. <br /> 3. Remove all cartridges, clean the contact points and then insert them back <br /> properly. Move the entire cartridge to its parking area. <br /> 4. Close the printer's cover, plug the power source, turn the printer on. <br /> <br /> 5. It should be working fine now. Mabuhay!!!
on Mar 24, 2011 | Office Equipment & Supplies
My canon pixma printer is showing error code 2 140 21 while scaanning???
i got this error while trying to scan. my ink cartridges were out of the printer (i was going to get them refilled). i stuck the cartridges back in and the scanner worked again.
Jan 20, 2012 | Office Equipment & Supplies
Where is the waste ink absorber on the pixma ip2200
Hi. I have researched on it and found that the procedure below resets the waste ink absorber most of the times and that too automatically. Hope it helps.
Canon Pixma iP1200, iP1600, iP2200 Resetter
  1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
  2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
  3. Run GeneralTool.exe
  4. Select the connected USB port number from USB PORT
  5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Mar 14, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
ayyub_thakur@hotmail.com
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon ip1880 printer service error 5202
Error 5202 means: UNRECOVERABLE ERROR. You need to return your printer to where you bought it and replace a new one if it is still under warranty.
Sep 30, 2008 | Office Equipment & Supplies
Canon Pixma iP1600- Service Error 5202
Silly as it my sound. But you did take the protective plastic cover off, didn't you?
Sep 01, 2008 | Canon PIXMA iP1600 Printer
I need to change the printer head in our canon iPF 700. I have the new print head but, it will not let me change the head becasue the ink level it too low. We replaced all 6 inks last wednesday and only...
you can solve this error code by removing the purge unit (take care of the ink).
Then you have to turn upside down the unit to check the gears. There is a white gear that moves in the ''air''. you have to re adjust the gear to transfer the move normally.
Then the problem dissapears.
Also you have to check if the motor is still moving.
Jul 08, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon PIXMA iP2200 InkJet Photo Printer Logo
612 people viewed this question
old marine
old marine
