Question about Intel D845EPI (INTELKD845EPILPAK10) Motherboard
D845epi ive just put motherboard in and it starts up without switching on and theres a red light on for front usb and i dont have any
  • 1 more comment
  • turbz Dec 10, 2007
    emmanuel i dont speak french and im in england
    there is power but not to drives so why no power to cd drive is it power supply or motherboard.i know power does go to mb and cd drive direct but why the problems.
  • Anonymous Nov 25, 2008
    i have d 845 board i want to know power and led connaction
Salut je m'apel emannuel je suis tecnicien de celulaire
je veux des solution sur les pannes de celulaire merci
mon numero es 06184385 aider moi merci
Posted on Dec 10, 2007
  • emannuel Dec 10, 2007
    tecnique avec concideration je atend
    je veux votre avie merci
I have an Intel D845EPI/D845GVSR Motherboard with 512MB PC266 Hynix DDR1 RAM. When i switch on my PC, the system starts but, fails to display even the first screen that it is supposed to display...
Couple of items to try. First disconnect everything except the power and the CPU. Does it give you a beep code?
If not your either have a bad power supply, motherboard, or cpu. (Only if everything else is disconnected.)
Second, If you did get the beep code then put the memory in and see if the system starts to boot. (Try without the screen connected first. If it acts like is going to start turn it off, plug in the mouse, keyboard, and monitor and try again.) ** I have seen where an add on video card would keep the computer from starting so try with the on board video first.**
Third, start adding one extra piece at a time starting with the hard drive.
Let me know if this helps or not.
Apr 22, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel DesktopBoard D845EPI Problem automatik open Bios
change jumper to its normal position then plug out ur powercable,now u see there is 1 battery in motherboard just remove it and start pc for a sec and then shutdown again and put battery back,start ur pc and check
Mar 07, 2010 | Intel Desktop Board D845EPI Motherboard
845gvsr startup problem
Try changing the CMOS Battery, Are you sure you are putting the jumper on the right pins, what happens if you save and exit bios without changing the jumper back, you may be resetting the CMOS with the jumper. does the clock keep accurate time if you leave the jumper on so you can get into the BIOS after turning PC off unplugging power then plug back in and check time in BIOS, if it is not keeping time, you may have a bad battery
Mar 28, 2009 | Intel D845GVSR Motherboard
are you using socket 478 motherboard or socket lg775 motherboard? if lg775 mobo you using try to remove the cpu heat sink and put it back again make you put correctly lock it perfectly and try to switch it on
Mar 12, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
I dont have d845epi mother board driver
but do u hav any idea how to down load mother bpard drivers
Feb 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel D845EPI Motherboard
I have been asked to clarify my problem, so I'll do that as brief as I can.
The Motherboard CPU Fan starts when the Power Switch pins are shorted together with a screwdriver.
Green lights appear on the Motherboard, but there is NO Screen on the Monitor, No Bios Screen, No Nothing !!!
It stays this way until the Power is removed from the Motherboard.
I hope that this clarifies my problem with this Motherboard for Colliewob. Any suggestions ???
Oct 10, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel D845EPI/D845GVSR won't power up.
oon mobo thers pins that go to front finsd ones says pw stick it in eash way try new switch also ove rthose 2 pins ok to get itto light up could be bad mobo
Oct 07, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
That green light indicates that the board is getting power. You should remove any excess components from the board, especially expansion cards like modems. Check to ensure the front panel header connections are properly connected (like the power switch, etc).
Lastly, ensure that all of the screws are in properly, so that the board isn't shorting out. As a troubleshooting step, you may try resetting the BIOS with the CMOS jumper to see whether a rogue setting may have caused the board not to power up.
Apr 07, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Seek Help
Sounds like the Power Supply may be going.
Dec 19, 2007 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel D845EPI (INTELKD845EPILPAK10) Motherboard Logo
98 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
