Question about Campbell Hausfeld Air Tools & Compressors
Model WL611200 30 gal oilless compressor will not start. When on/off switch is turned on, pressure switch buzzes and then breaker trips.Compressor is on it's own 20 amp circuit.
    Novelist:
  • 141 Answers
It could be a couple of things. First and foremost check the plug and make sure the continuity is good for the wires. I have found sometimes that cords get smashed and the wires will be making contact inside the plastic sheathing. Sometimes you cant see where the problem is visually. Remove the cord from the switch and test the continuity with a meter. Check across the poles to see if there is a connection there that shouldn't be. If there is continuity across poles get a new cord.
If your cord is good then it could be your switch. There may have been arching that caused damage to your switch. Check for burnt marks and any wires that are touching that shouldn't be.
Check all wiring to make sure it is correct.
Lastly, your motor may be stuck. Check motor and wiring.
Posted on Sep 11, 2009
Campbell Hausfeld
WL611200 air compressor is very hot when operating,do they require oiling at the piston/ cylinder?
Posted on May 21, 2014
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 17 Answers
What is wrong is the air in your tank is stopping your motor from starting .you need a air regulater i think cost about 20.00 dollars
Posted on Mar 09, 2011
Breaker trips when you try to start compressor motor spins a little before tripping breaker
Just fixed my compressor. It would start ok when the tank was empty but trip the breaker if it tried to start with pressure. Searched and read about weak caps, or problem with check valve or pressure switch leaving pressure in the pump head, etc. Turned out that the black plastic box which holds the 2 start up caps and is attached to the end of the motor with 2 screws had cracked on the bottom. The black box had tilted out enough that the start up caps switch was not engaging. Pushed on the lower part of the box and it started perfectly. Fixed it for the cost of some 2 part epoxy. Maybe not your fail, but definitely worth checking out first.
May 04, 2012 | Craftsman 33 gal Air Compressor 6 hp...
My Craftsman 15 Gal Air Compressor trips the electric breaker at start up no mater where I plug it in.
Apr 12, 2012 | Craftsman 15 gal Air Compressor 3 hp UMC...
Compressor starts innitially,then when pressure gets low it trips breaker when it tries to start back up.20 amp breaker to light switch to compressor is about 2o ft on12-2 wire. tried 30 amp breaker,does...
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Mar 19, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Compressor runs to 175psi but trips pressure relief when pressure drops tries to restart motor but motor wont turn blows breaker. changed whole pressure switch have same problem.
The problem is lilkely the check valve between the compressor and the tank -- it is alowing pressure to build from tank to compressor preventing the compressor from turning over. Clean, maybe replace, check valve...
Charlie
Jan 09, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
My Campbell Hausfeld 30 gal 6.5 hp oilless compressor, WL611201 trips the breaker when I switch it on auto. But will not trip the breaker if I use the breaker as an on off swithch. However, it somtimes...
not likely as your pressure switch is pneumatic, What else operates on that same breaker, perhaps replace the breaker as they sometimes get "tired"
hope this helps
Let me know
Dec 18, 2010 | Campbell Hausfeld Air Tools & Compressors
Craftsman 1 HP 8 gal vertical compressor.919
Sounds like the unloader valve is not working properly. The unloader typically is at the end of a tube going to the pressure switch. The unloader is tripped when the pressure switch cuts off. The purpose of the unloader is to bleed the pressure from the cylinder when the compressor cuts off so the next time the compressor cuts on it will be starting in an unloaded condition.
when the compressor cuts off you should hear a discharge of air for about 3 to 5 seconds if the switch is working properly. The unloader can be adjusted if necessary by loosening the jam nuts and adjusting the unloader towards the lever on the pressure switch.
Apr 05, 2010 | Air Tools & Compressors
Compressor trips breaker on re-load
if it has been an on going problem i would suspect that your power cord is too small,try a outlet closer to the breaker system.or get a bigger cord if one is used.is it maintaining pressure in the tank?if not a check valve is defective,you should hear air leaking if this is the case.let us know.
Mar 21, 2010 | Campbell Hausfeld Air Tools & Compressors
30 gal compressor - trips the breaker when I turn it on Model 919165130 Serial 2016180483
Try draining the air out of the tank,all of it.Now turn on the compressor,if it will come on,and build up to the cut off point,then the check valve/pressure release valve is bad,replace it.
Aug 29, 2009 | Air Tools & Compressors
Craftsman Compressor runs Intermittantly
I have repaired many craftsman compessors with the problem that you are having. I just use the process of elimination to find the broken wire. I use a short pigtail and attach it to the motor side of the pressure switch. This will isolate the motor from the switch and the power cord. Use caution not to overfill the compressor as this will test the safety valve. If the motor runs ok then move the pigtail to the powercord side of the switch. This will eliminate the power cord. If problem is within the motor check the connectors under plate and capacitor cover. To test the capacitor you will need to find a meter with cap test capabilities or repair shop will test for free. The cap should test within 95% or printed value in (uf). If all parts test ok then motor could have internal thermal breaker that is weak. Good luck.
Jan 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
224 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
