Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
My whirlpool- sounds like it is runnning just fine and will complete the whole wash cycle but the blades arent moving at all! Help
  • 47 Answers
Check dicharge hose hight, needs to be about 3/4 above the bottem of dishwasher
Posted on Sep 11, 2009
Whirlpool quiet wash plus dishwasher
Sounds like the timer module is going bad. Might be getting moisture on contacts. That would explain why it works one time and not the next.Just trying to help!
Aug 14, 2013 | Dishwashers
Machine is not moving through the cycles
It sounds like the motor in the timer is bad. This may require replacing the whole timer or just the timer motor in some cases. I hope this helps.
Mar 20, 2010 | Whirlpool Washing Machines
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
Aug 04, 2017 | Bosch Axxis+ WFR 2460 Front Load Washer
New Whirlpool washer model WTW5700SW rinse cycle doesn't worker properly. The water never fills the tub & continues to drain. You have to manually move the dial to the end of the rinse cycle to have...
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
Dec 03, 2017 | Whirlpool Washing Machines
Whirlpool washer Mod# TWAS750PQO, Ser# CR3520005
is it possible that the washer was overloaded? if so the agitator has little plastic "gears" that move the agitator one way only, they could have made the sound.
you can also check under the washer to see if anything (like a coat-hanger or something) is interfering with moving parts of the washer
Jun 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
Nov 29, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washine Machine
-Sounds like the timer is out. Check it out and replace it
Good luck
Mai
May 16, 2017 | Kenmore 22642 Top Load Washer
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
198 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
