Question about GE Refrigerators
Ge profile fridge TFH24PRSMWW, no ice delivery
I have a ge profile fridge TFH24PRSMWW. Ice is made but not deliver. Repair man says I need new control board, attaches to sliding levers for ice dispense at front of freezer section. Can you tell me part # and if you have?
SolutionGuy
  • 331 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Hi Urban Woman,
Unfortunately, your dispenser interface board has gone to appliance parts heaven and needs to be replaced. Fortunately it's relatively cheap. If I recall correctly, all you have to do to access the dispenser board is use a small flat screwdriver. There are 2 locking "tabs"/slots on either side and underneath the board (you will barely be able to see it, they're just that small). 6fb5654.jpg
Of course you already know that you need to unplug the fridge before doing any repairs so I can skip that part.
Insert your screwdriver into those slots and pry the bottom of the board out. Then grasp it with your hands and remove it completely. There are three wire bundles on it, remove them and re-install them on the new board. Then simply snap the new board into place.
This should take maybe 15 minutes to do... super easy job.
SG
p.s. Here's a link to the service manual, but the removal of the dispenser board is not in it (everything else is, though, so it may come in handy later)
p.s.s. Since you're going to be unplugging the fridge for the repair, you ought to go to Home Depot and pick up one of these to plug it back into. Transient voltage spikes are most likely the cause of all your woes... including the main board that was replaced.
Posted on Apr 01, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
Sea Breeze
  • 4654 Answers
SOURCE: We have a GE Profile refrig, circa 1995. The ice
If you are sure it is caused by the ice maker or if it is not it can be fixed. The only way an ice maker would leak like that is if ice is blocking the inlet tube and when the water comes on the water is spewed in a different direction than the ice maker. Most times this is caused by a slow leak in the water control valve for the ice maker side at the rear of the refrigerator. You can stop the problem by melting the ice in the fill tube with a hair dryer and keeping an eye on it until you see ice beginning to build up there again. That would indicate a slow leak in the water control valve that is not closing all the way when off. The other reason for large pools of ice in the freezer is a frozen over defrost condensate drain behind the cover in the rear of the freezer and would require you to unplug power and remove the rear panel. I will try to get some photos and a link shortly that covers that problem a lot more in just a few minutes. Sea Breeze
Posted on Aug 20, 2009
SOURCE: ge profile artica ice dispenser and chute frosing.
I have just solved my own ice dispencer frost problem.
1. The control pannel has to be removed. Look up under the pannel and you will see 3 small holes were the snaps lock in. Press a small screw driver in to the right most hole as you pry outward with a 2nd small screw driver. Unplug the control pannel.
2. Now you will see 4 screws, remove them and pull that segmant out.
3. Remove the 2 screws that hold the flapper in place.
4. Remove the 3 screws holding the solenoid in place.
5. Check the solenoid plunger for rust. If it is rusty, sand it down, clean it and the bore and spray paint the plunger. I use a 12 minute enamel and sped up the drying prosses with a hair dryer then cooled it in the freezer when no longer tacky. Apply a small amount of Pam to the piston and bore. Also Pam the pivot ends of the flapper arm and at the point were the pivot arm engages the solenoid.
You may have encountered a lot of mold as I did in complete shock. Use bleach wipes and dissasemble the flapper all the way for cleaning. It breaks down from the pivot arm and the rubber disc and foam back come appart also. When you have cleaned to your satisfaction, reassemble all small parts and replace in reverse order. Then remove the frost and the blockage were the ice comes from the tray and you should be all set.
Posted on Oct 24, 2009
Have a ge profile refrigerator went completely dead,repair man replaced mother board and control panel still not working, fridge is only 14 months
If there is no power after the repair man replaced the board and panel, the repair job is not complete. Have the repair man finish the job.
May 03, 2016 | GE PFE29PSDSS 29 cu. ft. French Door...
Ice under the deli drawer
it could be that u have a leak.. sometimes this happens when to much water is delivered to the ice tray and it overflows a little leaking into fridge. if that is happening then u most likely have a problem with the water inlet valve at the back of fridge, u can buy the part on line at appliancepros.com. good luck
Apr 13, 2014 | GE Refrigerators
PDS18SBMRBS model GE Profile fridge. The fan
the heater unit might be weak and usualy it is a hlogen light that need to be replace , so the defrost will be better
Jan 01, 2010 | GE Refrigerators
I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
My GE fridge makes Ice but can't get any water?
He is saying the heater in the ice tray located on the bottom that helps loosen the ice before it is dispensed to the ice pan.
A new ice maker for your fridge can be purchase for less and you can install it yourself. Below is my site link, just put your model number in the search feature or the part number WR30X10093 of the ice maker. We also offer free help and assistance, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 28, 2009 | GE Profile PFS22 33" Artica French Door...
GE Side by Side Model #TFH24PRSMWW Ice maker
The on and off switch of the ice maker on the ge side by side model has fell off and appears broken. please instruct with a diagram how to reattach.
Oct 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile side/side refrigerator which was delivered on 4/19/08. When the ice comes down the chute it makes a lot of noise - so much noise that you cannot hear another person speak within the...
Hello azcowgirl19
Welcome to fixya,
You said, You have a GE Profile side/side refrigerator which was delivered on 4/19/08. When the ice comes down the chute it makes a lot of noise - so much noise that you cannot hear another person speak within the same room. Is there anyway that this clattering can be cushioned?
Also, the ice seems to clump up into a large ball and when it tries to go threw the coils, it shakes and rattles the entire appliance. Other than removing the lg clump of ice is there anyway to prevent this?
Yes I do recognize the problem.
The ice maker has a couple of defective parts in it!
Lucky for you you still have a warranty for this GE Profile fridge and did not waste anytime looking into it!
In the USA, Call GE at 1(800) GE CARES , and tell them the ice maker has multiple problems so they can service it while you still have your full parts and labor warranty!
Let me know how it goes!
Please remember to leave a rating at our site before you leave!
Thank You, Huuum
Sep 30, 2008 | GE Refrigerators
Ice Dispenser
If you access the ice container and remove any partially melted ice - maybe the ice maker will work. We had a similar problem. We opened the ice reservoir and discovered ice cubes that had partially melted together. Once we removed those, the ice maker and water dispenser returned to normal. Now we check every so often.
Apr 04, 2008 | GE Profile PSW26P Stainless Steel Side by...
I have a new side by side Whirpool serial ED2JHAXT001 that has an ice jam in the ice cube maker. I have mislayed my manuel or accidently thrown it away. How can I break it up without damaging it or do...
You need to first of all defrost it by unplugging overnight.
Then run it again and if the ice builds up again, then you may have a problem with the defrost heater.
Let me know if this helps.
Mar 12, 2008 | Refrigerators
Refrigerators Logo
269 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
