Question about Sanyo PLC XU48 Multimedia Projector
Thought the bulb was bad, replaced and still no light.
The orginal problem had the picture gradually getting dimmer and dimmer. I assumed the bulb was bad. Replaced the bulb and I still get no light from the bulb. The fan runs and the machine seems to power up fine just no light.
Could I have gotten a bad bulb?
Is there a way to test?
  • 2,237 Answers
Where did you get the lamp from? if you got it from a reputable dealer, then i'd say the ballast is bad and needs replacing. if you got it from "bob's bulbs", then it may be the lamp. but the only way to test it is to put it in a known good projector.
Posted on Sep 11, 2009
Panasonic rear projection tv -tc51p400h.Red light off when it power on and return to stanfby mode after 5 seconds.please tell me the reason
Check the owner's manual. If you no longer have the owner's manual, this could be due to a bad/weak projector bulb. Many projection TVs shut off when the bulb gets old and can no longer provide a good picture. Owners often don't notice the bulb getting bad because it so gradually gets dim.
Nov 22, 2016 | Panasonic Televison & Video
Humming and failure to dim
Bad dimmer. Probably not using a high enough watt rated switch. Add up the total of all bulbs to be dimmed and get appropriately rated dimmer. 8x60 watt bulbs=480 watts. Make sure dimmer is rated high enough.
Feb 09, 2014 | Leviton Decora Light Dimmer Switch
Toyota Echo gauge cluster lights wont turn on?
Check for voltage where the wire from the switch connection to the cluster if you have voltage then something is wrong with the cluster
Jun 17, 2017 | Cars & Trucks
I just replaced my bulbs on my ceiling fan light fixture with the compact flourescent bulbs 13 watt to replace the regular 60 watt bulbs but they are flickering now. Could there be a problem with wiring...
Your remote control I would assume includes a dimmer for the light. CFL bulbs are not compatible with dimmers. If it has a dimmer, you must use incandescent bulbs.
Feb 14, 2011 | Hampton Bay 52 In. White Redington...
I have a 96 suburban and the headlights don't come on at all i have checked and replaced the fus, headlight bulbs and head light switch. i realized i am not getting any power to the bulbs. is it posible...
Its the dimmer switch.The hot wire at the dimmer switch is Yellow. Then low beam is tan, and high beam is light green . be sure the yellow wire has 12v. then check the other wires, if no voltage, then connect yellow to the tan or lt green, if lights work, then the dimmer switch is bad.
Nov 10, 2010 | 1996 Chevrolet Suburban
How do I change the bulbs in the instrument panel?
I thought I had that problem on an 02 outback, so I googled and looked on youtube and found some folks who had pictures and videos of themselves pulling the radio and instrument cluster out so they could replace the bulbs. I even bought new bulbs. Then I discovered the cluster light dimmer switch on the turn signal stem and I just turned them on! So I know you can find this on youtube and a google search, so look there.
Nov 03, 2010 | 2004 Subaru Outback
Hi, I have a leviton slide dimmer controlling 4 pot lights with gu10 bulbs. There is also 6 receptacles on this 15 amp circuit. I had a regular 2 pole switch on there, with no problems. When I converted...
You said they are 50 watt GU10's, so I would assume they are 120V halogens, and you must simply have gotten a bad dimmer. But if these GU10's are 50 watt equivalent (LED's or CFL's) then the bulbs will have their own transformers built into them, and would be incompatible with a dimmer switch. It also might be the case that you have low voltage halogens which would use a transformer, shared or individual, and these would also be incompatible with a dimmer. (I don't know offhand if GU10's are available with low voltage halogens.)
Sep 17, 2010 | Leviton WHT SLIDE DIMMER
How to replace dashboard lights 2006 f-150
have you tried the dimmer switch? its not normal for those to go bad especially all of them at once could possibly be a bad insterment panel
May 10, 2010 | 2006 Ford F-150
Humming inside the switch
Is it connected to a fan motor also? - most dimmers are for lights only - if there is a ceiling fan connected you may experience a humming sound from the dimmer
Nov 12, 2008 | Lutron #D-600PH-DK 600W SP Push Rotating...
Sanyo PLC XU48 Multimedia Projector Logo
572 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
