Question about Brother MFC 4800 All-In-One Laser Printer
Cant printer elect faxs have M.F,C 48000 - Brother MFC 4800 All-In-One Laser Printer
I am using the PE 16 & suddenly I get a comm. error when I try sending faxes, both using the automatic dialling or dialling manually - I tried unplugging from the elect. & the phone line &...
comm error could mean numerous things is the phone line cord your using new? do you hear it dailing or a dail tone? are you on dsl as far is Internet these use filters that can mess with communication.Does it use standard dailup to send faxes
Jul 04, 2011 | Xerox WorkCentre PE16 All-In-One Laser...
8500 hp printer -- cant get red of message -fax log full
clear the fax log...
go to setup menu basic fax setup... scroll to fax log... clear fax log....
in some printer you can find the fax log in the fax settings or advance fax setup..
Feb 16, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
FAX RX IN MEMORY AND FAX TONER EMPTY ERRORS AND I CANT RECEIVE MY FAXES BUT I CAN SEND IT...PLZ HELP
It sounds like your toner has ran out, so you cant print any more faxes out, the memory saving the unprinted faxes has filled up and cant save any more messages.
Replace the toner and let the machine print out the saved faxes. You should then be back to normal
Sep 04, 2010 | Sharp AM-400 Digital Multifunction Printer
Cant receive a fax now . Only thing that has
The new phone change is exactly what's effecting your fax receiver, plus, the automatic answer feature takes over before the printers fax answerer can pick. I'm assuming that you can fax out. You need to check the operators book of the telephone to see what settings need changed to add a fax machine. (four-in-one)
Dec 01, 2009 | Brother MFC-5440CN All-In-One InkJet...
Cant receive faxes
plz check all cables properl there might be damaged one ... then check you fax machine ink ..if none seems to be the problem the get it once serviced it will get back on working
Aug 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I cant receive fax. it has some in the memory.
if there are a message like empty cartriage or low cartridge that means
the printer want new cartridge for print fax, when it print another document and also print reports without trouble.
Jun 25, 2009 | Lexmark X5470 All-In-One InkJet Printer
Help with fax please
Please click the below mentioned link to download the Fax Solutions software. But, it is supported for upto XP.
Fax Solutions Download
Thank you
Dec 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Cant recieve fax
please help me how to switch my machine Brother MFC440cn to fax/tel mode.
Oct 26, 2008 | Brother MFC 420CN All-In-One InkJet...
How can i receive fax on my printer
Your printer should have software to install for the fax. Then go to control panel and click the fax machine, check your connectivity settings and make sure the phones numbers are correct for out-going and the in-coming settings.
If you do not see the fax in printers then the fax part of the printer has not been installed, then install hardware, then software and use the install wizard if you have one. This helps too.
Jul 23, 2008 | Lexmark X6170 All-In-One InkJet Printer
Brother MFC 4800 All-In-One Laser Printer Logo
50 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
