Question about Garden
I have a mtd mower grinds going into gear and the blades run constantly .what could be wrong i put on new belts
  • 155 Answers
Hi these machines have to hve the drive belts stop completely for them to go into gear smoothly, Also if non genuine belts are used it will cuase a lot of problems. There is so many variations between different models of mtd units. To check if you have the right belts you can check it up on a site called pats small engines.
Posted on Sep 12, 2009
Blades keep running in all gears on my mtd 420/38
Assuming you have put the blade drive lever into 'disengage' check the blade drive belt tension. With blade disengaged, belt should have significant slack. You may need to adjust the control cable, adjustment is usually on the mower deck; or you may have some debris on the deck preventing the pully to release belt tension
Jun 26, 2014 | Garden
Mtd engage blades it smokes and make noise
Have you physically moved each blade by hand (with the machine shut-off),spark plug disconnected to see if both or all of the cutting blades move freely if there is any binding you probably have a bad blade spindle bearing . If those move o.k. then you're going to want to check the pulleys on top of the deck, one of these which do not go to the blades may possibly have a bad bearing and is not moving freely causing the belt to be burning up.
Dec 03, 2012 | Garden
Vibrating 38" deck on MTD yardman mower
Hi, first replace the blade spindle bearings, if you had to hit them to free them up the bearings are shot. Secondly, replace the deck belt. Because you engaged the blades with a siezed bearing the belt will have a worn section where the v will be thinner thus causing the vibration as it passes through the pulleys. Regards Phil.
Jun 19, 2012 | Mtd Garden
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
My 12.5 hp yard machine by MTD is not going into gear and there is no grinding
my yard machine 42" ride on is making loud grinding noises coupled with slipping and jerking wile driving. could this be a loose belt or is the rear axle breaking ?
Nov 25, 2009 | Mtd Garden
Mtd model series 790 mower wont move, belts are fine and transmission wont go in nuetral
mtd 1993 riding mower model 828 I was mowing then tractor stopped and wont go forward or backward It runs fine, and blades
seem fine. Drive belt looks fine.
Sep 17, 2009 | Mtd Garden
Mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Aug 23, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
MTD mower won't engage traction belts
Check to see if rear axle is broke. Jack up the rear of the tractor, put it in gear and spin one of the rear wheels, the one on the other side should spin the opposite way. hope this helps
Jul 13, 2009 | Garden
MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Jun 28, 2009 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
