Question about Xante Ilumina Digital Color Press Printer
ERROR code my machine is D435. When i switch it on, it brings me the following: Functional problem SC 322-00 A spanner-like icon blinks in red. How can i solve this problem?
Tc-p60st50
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 25, 2016 | Televison & Video
What do I do to make Minolta CSPRO 1054 function following the red spanner icon showing on the panel?
Open close the front door. What code is it that gave you the spanner wrench
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 08, 2016 | Konica Minolta Office Equipment & Supplies
ENG:prcon.c
Turn ON the copier ,enter in SP mode as follows:
Press the mode/clear(yellow)key
enter "107"
press the clear/stop (red) key for more than 4 seconds
Touch SP mode on the display
Open the front cover
Turn OFF the copier
Wait 3 minutes
Closed the front door
Turn ON the copier.
This error code appaires when using for use OPC drum and not original genuine Ricoh parts(Katun and other brands)
Feb 14, 2013 | Ricoh Aficio 2035 Copier
Error code sc 302
Hi
This error indicates problems with the laser motor on your printer.
Have it replaced.
Mar 01, 2012 | Office Equipment & Supplies
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
Apr 15, 2011 | Toshiba e-Studio163 Copier
My Toshiba e studio 163 coupier machine key board not functioning, a spanner mark continue blinking which is located on front panel. Please send me solution.
you have a error code you must press 8+clear buttons down together and it will give you a code i must know what the code is
Feb 20, 2011 | Toshiba e-Studio163 Copier
I HAVE A PROBLEM WITH MY COPIER,NASHUATEC D435.
Enter in the service mode(SPmode),open the front cover and turn OFF the copier.Unpluged the machine,wait 10sec.amd pluged ON.Before clean the thermistors and thermofuses in the image fusing unit.Close the front door and turn ON the copiers.
Feb 08, 2010 | Ricoh Aficio 450 Copier
My copier keeps indicating the spanner function.it is saying problem sc5042
my think its not sc 5042 it will be SC542: Fusing temperature warm-up error -Definition- [A] The fusing temperature does not reach the fusing standby temperature within 50 seconds after the main switch is turned on. - Possible causes - · Fusing thermistor defective or out of position · Fusing lamp open · Fusing thermofuse open · Power supply board defective · Poor connection of the fusing unit
5-810 SC Code Reset Resets any service call condition. After performing this SP mode, turn the machine main switch off and on. See "Troubleshooting - Service Call Conditions" for how to use this mode. 0: No 1: Yes
Sep 21, 2009 | Ricoh Aficio 2022 Black and White Copier
Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Oct 29, 2008 | Office Equipment & Supplies
Sc 322 on a 3045. cudnt figure out how to fix this problem. everytime i switch it on n off sc code disappears, once i print the paper stops at the registration roller and brings up the sc code. dont...
Another poblem with this machine is that the sync detect for the 400 dpi and 600 dpi could be off. Go into service modes by pressing the yellow clear modes key then pressing the numbers 1 0 7 then hold done the red stop key till you see the display change. Now go into copy sp, then hit the 2 in the window {drum}, next use the page down button located in the middle of the screen till you see the one that says 2109 LD Beam Pitch Adjust. Go to number 2109-8 beam pitch data reset. execute then go to 2109-1 and set it to 144 then hit pound. Now go to 2109-3 and execute. last go to 2109-2 and set it to 168 then hit pound. Now go to 2109-4 and execute. exit out of the service modes window. now try to run a copy and a print. If these fail the you either need to clean the laser assembly, a polygonnal mirror moror or laser drive unit.
Oct 16, 2008 | Ricoh Aficio 1035 Copier
105 people viewed this question
Top Xante Office Equipment & Supplies Experts
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
