Question about GE Dishwashers
Ge Profile dishwasher Showing PF Fault cannot reset
Showing PF Fault Cannot reset
SOURCE: C5 error on GE Profile dishwasher
C5 - Low Water Fill - This error usually indicates bad water inlet valve. Check for low water pressure to unit.
Posted on Dec 21, 2008
SOURCE: Baumatic BDW13 14 dishwasher SHowing E3 Fault
word_answers.gif I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
Posted on Jan 23, 2009
SOURCE: purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Posted on Aug 06, 2009
  • 246 Answers
SOURCE: Replacement Door Panel for GE Profile Dishwasher
Are you trying to replace the microwave door or the GE dishwasher. Either way, www.applianceart.com (under the stainless steel section) has this roll of stainless material that you apply to your appliances. I saw it on the "Today Show." Its basically faux stainless. We put it on our refrigerator and it looks and even feels like real stainless steel. Its really cool. I think its called stainless foil or something like that. Also if you're looking for a stainless panel for your dishwasher they sell actual stianless panels there too.
Posted on Feb 25, 2010
SOURCE: GE Profile Dishwasher does not drain. model #
I had a similar problem with a GE GSD5811 model. The hoses were clear, and the auxiliary pump worked fine. It turns out that it was the "piston" assembly that had basically disintegrated over time. This part diverts water to the pump during the drain cycle.
To check it, remove the mesh filter at the rear of the inside of the machine, by carefully unclipping the heater element from the back of the machine and removing the 4 hex-head screws securing the filter panel.) Unscrew the piston assembly from the tub, and pull it out. If the sealing plunger has deteriorated or is jammed, replace it. The part number for the "piston and nut assembly" for my machine (and probably numerous others) is WD24X10018. It should cost anywhere between $10 and 16, depending on where you shop.
Another possibility is a bad drain solenoid. (This is what actually triggers the piston assembly during the drain cycles.)
Posted on Apr 08, 2010
My electrolux dishwasher is showing a PF error and it will not work?
Code PF means power failure turn off the breaker that handles the dishwasher for a few mins. then turn it back on. it should reset itself
Jun 05, 2014 | Dishwashers
Pf code came on and then went to er code reset power and pf code comes up then starts showing 37-36
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
,./;''l
Jun 18, 2010 | Frigidaire 24 in. PLD2560LCC Energy...
GE JBP45G oven display module keeps on showing ''PF'', whether I turn oven on or off.Have to constantly reset clock to make the ''PF'' message dissapear. My broiler element is not working,but why is ''PF''...
I can easily explain the "PF". It means your EOC or electronic oven control/timer is losing power for some reason, hence the "PF", for power failure.
I`d suspect the control itself is defective or at fault as they have built in transformer`s that can become faulty.
I would first insure your power supply cord is secure and in good condition in the wall or you don`t have loose wires going to the timer.
Hope that help`s move you forward, let me know if I can assist you further.
Good luck.
macmarkus :)
Feb 10, 2010 | GE Ovens
Ge profile dishwasher runs for hours
HI, this will occur if there is a major control fault in the timer module or, main control board. Depending on you model, you will need to replace the timer or, control board in this case. this will fix this issue
Jul 15, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
Dec 21, 2008 | GE Profile PDW8400J Built-in Dishwasher
GE Profile Dishwasher Mod. #GSD 4430
I have the same problem right now. What is the casue?
Oct 19, 2008 | Dishwashers
GE profile dishwasher
I talked with a GE techy, and was told to either turn off the circuit breaker or unscrew the fuse for the power to the dishwasher, wait 45 seconds, then turn the power back on. GUESS WHAT? IT WORKED!!! try it.
Mar 17, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
185 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
