Question about Ryobi 9 in. Benchtop Band Saw
Where can I find replacement blade gide bearings for a ryobi 9'' table top band saw BS 903
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
The part number is
080007005056 . They are $9.92 each and you can get they from Ryobi's website.
Click this link and enter the part number above then click on the little check mark to the right of the listed part.
Posted on Sep 16, 2009
Can you use a 59 1/2 in. blade on a 9in ryobi bandsaw.
I think 59 1/2 inch blade will still fit on your bench top band saw. But try to give a call you supplier for assistance .
Dec 20, 2012 | Ryobi 9 in. Benchtop Band Saw
Ryobi 902 bandsaw makes high pitch noise. have adjusted all guides and thrust bearing
The noise might not be coming from the blade, but perhaps from the bearings on the top or bottom wheel. Unplug it and open the covers. With the blade still on, turn the wheels by hand to see if you still get the noise. Then remove the blade and turn the wheels independently by hand. Then plug it back in and run the motor (with the blade still off!). Of course with the blade still off, the load on the wheel bearings will be very light, so maybe you can provide a bit of load by pressing a wheel or or caster against them as you turn them. Be careful. Good luck!
Oct 24, 2012 | Ryobi 9 in. Benchtop Band Saw
Blade will not stay strate when you put presher on it
There should be guides where the blade comes out of the top housing. These guides should be adjusted so that they barely touch the blade when no pressure is applied. They keep the blade straight and the bearings (located beneath the table) absorb all the forward and backward pressure. Hope this helps!
Aug 28, 2010 | Ryobi 9 in. Benchtop Band Saw
I can't get this saw to cut straight or square I
Band saws pull to one side on straight cuts, it's a function of the blade torque. My 14" saw pulls to the right. There's nothing you can do to stop this, you have to be aware of it so you account for it on free cuts and know to put your fence on that side so the wood pulls into the fence instead of away from it. Squaring the blade to the table is easier. Do not go by the tilt angle guide. First make absoutely sure all of your blade guides and bearings are properly alligned so they aren't pushing the blade out of line. Use a square to get it close then: using a 4" x 4" block of wood, make a light cut in the wood only deep enough to mark the wood from top to bottom. Turn the block over 180 and try to make a cut in the previous cut mark. If the cuts line up you're there. If you get a V or X you have to make adjustments to the table making sure you tighten the trunion locks tight. I had one of these, it's not a high end saw so don't expect a lot from it.
Aug 23, 2010 | Ryobi 9 in. Benchtop Band Saw
I need the manual for my ryrobi 9" band saw
look at freemanuals.com
They may have yours on hand
Mar 27, 2010 | Ryobi 9 in. Benchtop Band Saw
1/8'' blade keeps jumping off wheels on Ryobi BS 900...!! Checked wheels for alignment and both are square to each other. TRension seems right, although I can't find manual to confirm proper tension....
I found a manual online, however it did not give specifics on blade tension. I do know that the blade has to be pretty tight and that it the blade should be just touching the bearings on the back. I hope this is enough help, if not let me know and I'll see what else I can do.
Jan 09, 2010 | Ryobi 9 in. Benchtop Band Saw
Cut is always crooked. From the top to the bottom of the cut is always crooked. Can not get the saw to cut a 90 degree ( or even close to 90) angle. Even of I adjust the table to be out of square to the...
It sounds as though you may be cutting too quickly. Try decreasing the pressure you are applying to the wood.
You could also try tightening the blade more, until it PINGS when you flick it with your finger.(When it's stationary of course)
I'm assuming your guides are adjusted correctly.
JR
Sep 27, 2009 | Ryobi 9 in. Benchtop Band Saw
Manual needed for Ryobi 9 inch Bandsaw - BS 900
Here is the ryobi tool website for your saw:
http://www.ryobitools.com/catalog/power_tools/band_saws/BS903#
In the lower left hand corner is a link to the manual (.pdf file)
May 29, 2009 | Ryobi 9 in. Benchtop Band Saw
Delta shopmaster bs 100 band saw
Hi, This Delta saw uses a 59 1/2 inch blade ( 1511mm).
Good Luck, this should Fixya!
Mar 06, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Ryobi 9 in. Benchtop Band Saw Logo
355 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
