Question about Garden
After adjusting deck 1042 cub cadet still cuttinglow right side
After adjusting deck 1042 cub cadet still cutting low right side
  • 21 Answers
Try checking to see if perhaps the blade is bent if not blade maybe the spindle or possibly the bearings are bad on the spindles causing them to not run true, also are all tires inflated properly good luck
Posted on Sep 12, 2009
Cub cadet troubleshoot
check make sure all tires have same tire inflation
Aug 24, 2014 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
How do I adjust reverse on my cub cadet 1042
there is a linkage adjustment that runs from shifter to rear end there is also a adjustment on petal if it is hydrostatic
Aug 24, 2013 | Cub Cadet Garden
How do you remove the blades for sharpening on a CUB CADET 1042?
when i do mine i drop the deck off then remove the blades and clean the old grass off at the same time it keeps it from rotting out
Jul 01, 2012 | Cub Cadet Garden
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Sounds like a blade is hitting something on my Cub Cadet LT 1042.
with tractor off and key in pocket check blade for straightness if straight then check by moving it up down if loose check retaining nut if nut tight then possible mandrel bearing burnt or shaft bent also check the mandrels are bolted correctly to deck lastly but least likely is a bent deck
May 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet 1042 leaves a stip down the center when mowing. I have new blades put on by the dealer and this seems to be an ongoing problem.
I had the same. design of the deck is not good. grass will build up and insolate (like a donut) the blade from cutting the immediate blades. FIX - replace custom blades with "Gator Blades and the claws will free up the cluster of interferances of grass, kick it out, thus allowing the blade free space to cut the immediates blades of grass.
Hope this helps as it was my last trial of fixes. IT DOES WORK.
J THOMAS
Apr 26, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 1042 wuth 42" ower does not cut even. This is my 3rd cud cadet and theu all have cut unven.
There are just so many possibilities. I doubt this is specific to Cub cadet. Usually it is a result of a misalignment.
You can go here for some more information
Lawn Mower quality of cut
Dec 21, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
274 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
