Question about Fuji FinePix A330 Digital Camera
It just says no image when turned on - Fuji FinePix A330 Digital Camera
  • 149 Answers
YOU HAVE CAP THE PLAY MODE MOVE TO CAMERA MODE
Posted on Sep 12, 2009
Error Code C-2152 wen i power the machine at begin
Transfer Belt Separation
• The 1st Image Transfer Pressure/Retraction Position Sensor doesn't turn ON (Retracting) even after the lapse of a given period of time after the 1st Image Transfer Pressure/Retraction Clutch has turned ON during the Transfer Belt is retracting. • The 1st Image Transfer Pressure/Retraction Position Sensor doesn't turn OFF (Pressuring) even after the lapse of a given period of time after the 1st Image Transfer Pressure/Retraction Clutch has turned ON during the Transfer Belt is pressuring.
Sep 22, 2015 | Konica Minolta BizHub C252
Error c2652 in konica minolta c250
C - 2651 Cyan imaging unit EEPROM acces error
C - 2652 Magenta imaging unit EEPROM acces error
C - 2653 Yellow imaging unit EEPROM acces error
C - 2654 Black imaging unit EEPROM acces error.
Clean the connection between the imaging unit and the machine if dirty.Reinstall imaging unit or change imaging unit.
Try reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON the copier.
Keep pressed the Utility key when the Trouble resest message is displayed.
Release the Utility key and touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Apr 16, 2013 | Konica Minolta bizhub C250 All-In-One...
Ko0nica minolta c350 blad c0016
Pull out the black image unit shake the image unit side to side you are going to try to spread the developer and toner inside the image unit along the entire length of the image unit, I bet the image unit was stored standing up and the person just plug it in with all the developer sitting at one end the motor that turns the drum had a hell of time trying to turn always store image units laying down always before placing them inside the machine shake the image unit to spread the developer along the image unit, if this does not work get a new image unit or the motor is burned out worse case control board for the motor is bad$$$$$$$$$$$$$$. Open close front door to reset
Jul 26, 2012 | Minolta C350 Color Printer/Scanner/Copier
Hi, we have the hp color laserjet 2840 series and we are getting a supply error (10.1004). The picture shows that there is a problem with our imaging drum. We bought a brand new imagind drum and it is...
Reseat the toner cartridge. Turn the printer off, and then back on again. You may want to try a new cartridge, but if that does not eliminate the error, call your HP support line. If the imaging-drum light is still blinking but the Attention light is not on, you must replace the imaging drum before the printer can continue printing. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition. The printer has determined that it cannot read or write to the e-label on the imaging drum.Reseat the imaging drum, and then power cycle the printer. If this does not work, replace the imaging drum. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on. If the problem persists, replace the imaging drum E-label reader. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition.
If Hope that this helps,, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks,Joe
Feb 04, 2011 | Office Equipment & Supplies
Memory card contains no images after camera turned back on
Are you able to access the images using a card reader on your computer ?
Apr 18, 2017 | Nikon Cameras
It may be the images are there but the camera is not reading them... I would try to find a place (possibly a photo retailer or a computer repair place) with a card reader to check out to see if that is the case.
Dec 15, 2008 | Nikon COOLPIX L18 Digital Camera
Toshiba 65H80 Rear Projection Multi Image Problem ( Trailing )
There is a problem in the imaging circuitry in your Toshiba. It could be anything but most likely in the focusing circuitry. I would have a certified Toshiba repair on it.
Sep 17, 2008 | Toshiba 65H80 65" Rear Projection...
I get a mirror image
when you turn the camera the other ways and stuff.
it looks all weird. all you have to do is press
up or down on the volume key. and that will convert
the image the way you like it.
Feb 15, 2008 | Samsung SGH-D820 Cellular Phone
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Feb 11, 2007 | Mitsubishi X490U Multimedia Projector
Fuji FinePix A330 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
