Question about Mitutoyo Dial Calipers
How to disassemble dial calipers - Mitutoyo Dial Calipers
    Sergeant:
  • 384 Answers
I wouln't do it, you will strip the rack & gears. But if you must, a 10 pound hammer would make short work of it.
Posted on Sep 11, 2009
I have p# 505 645 50 . when i slide to open it feels like there is somthing caught in the teeth of the rack. how do i remove the dial assy?
Don't take it apart just get a toothbrush or small fine wire brush and clean out the teeth.Use an air gun to blow out behind the dial as well but only on the frame and not the dial part itself. Also check to make sure that the locking mechanism is loose enough as this will cause it to feel like it is jamming.
Mar 02, 2011 | Mitutoyo Dial Calipers
The face on my dial calipers is turned 90 degrees to match up to 0. How do I adjust it to be correct and readabel?
There should be a small set screw you can loosen by hand and adjust the face of the dial to zero with the jaws closed....this is typical of most calipers...it allows you to zero the dial on a given thickness of material and only read variations based on that thickness.
Take care.
Dec 09, 2010 | Mitutoyo Dial Calipers
How do you rezero a 505-637 mitutoyo dial caliper
Fully close the caliper. The pointer should be pointing about straight up or close to it. Losen the knurled screw which is located on the circumference near the bottom. Now grab the dial and turn until the zero lines up with the needle. Re-tighten the knurled screw.
Dec 03, 2010 | Mitutoyo 0 150mm X .02mm Dial Caliper
My caliper is .030 off of zero I don't know how this happened . How can I fix this problem
Just loosen the screw that clamps the dial in place, close the jaws, and turn the dial to zero. Then tighten the screw clamp
Sep 18, 2010 | Mitutoyo Dial Calipers
Fowler 12" dial caliper measures 0.025 when shut, how do I zero
There should be a small thumb screw near the dial that you loosen to turn the dial to zero it, then re-tighten the thumb screw.
Apr 27, 2010 | Fowler Shockproof Dial Caliper - 0 - 6"
I zero my caliper and go out an inch and then close and it is rea
The dial and needle are not aligned properly. I have several calipers (all vernier) which were past down to me from my father. Some are almost 75 years old and still measure +/- 1000th! I'd go out and get a good old fashioned caliper.
Feb 17, 2010 | Mitutoyo 505 677: Test & Measurement...
Dial calipers .06 off from zero
With the caliper set to zero, you must turn the dial body to set it to zero. This should be done every time before the caliper is used.
Jan 24, 2009 | Measuring Tools & Sensors
Mitutoyo Dial Calipers Logo
750 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Glenn
Glenn
Dragan Manojlovic
Dragan Manojlovic
Level 1 Expert
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
