Question about GE WSXH208A Front Load Washer
The door lock isn't engaging.
Worked fine yesterday. I put a load in this morning, pushed start, I get 4 beeps and notice that the door lock light won't come on and I didn't hear the lock engage. I've tried opening and shutting the door and unplugging the unit.
  • 47 Answers
You may have bent thr hing on the door if you lean on them on top they will bend try a little lift on the door then close
Posted on Sep 11, 2009
Testimonial: "I really thought that may do it...unfortunately that didn't fix the problem. =( maybe a bad sensor?"
Why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Nov 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Car Won't Start
Battery , cables , connection's could be bad. High resistance in a cable , connection , Ground connection Corrosion ... Voltage drop test the electrical circuits .
Voltage Drop Test
Voltage Drop Testing the Starter
Jul 13, 2017 | 1999 Nissan Altima
Whirpool Fronload Dryer has power, timer cycles through, but it is not running. The dryer worked two days ago when I ran a load. I went to dry a load this morning and it turns on, everything lights up...
The reasons can be a fault on the program controller unit but as the door does not close the program also will not move further. This must be the clue to the fault. Remove and check the lock and the settings. manually close the door with force and see if the program cycle starts, if not check the door switch and the control panel. Also check for output when the timer counts down. If not the controller unit must be checked for possible problems.
Nov 14, 2011 | Whirlpool GEW9250 Electric Dryer
Door not locking
Doot lock hook may not be engaging or door lock is faulty- wiggle the door around while pushing on it, check the door hook , replace the electric latch
Sep 12, 2009 | Samsung WF337AA Front Load Washer
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Car won't start. Believe kill switch is engaged.
Do you have a chipped key {small black thing in the middle of the key} if not you need to take your registration into the dealer and order a new key.
Apr 03, 2009 | 2006 Dodge Charger
Door locks and F9 fault codes
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Pushing Start Button only results in "Beep, beep, beep"
Need to check that the lid is shut properly and the door is locking. You don't mention an error code in the display. Make sure there isn't one showing.
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
GE WSXH208A Front Load Washer Logo
220 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
