Question about Garmin GPS 12 GPS Receiver
Garmin GPS 12 suddenly turns off
My seven year old Garmin GPS 12 has recently begun turning off all by itself. It does not do the 2 second power down, it just blacks out as if the batteries were removed. (It does this with fresh batteries) However, it only does this after several seconds of being moved around, not when it is sitting still. The coil spring battery contacts seem to apply sufficient pressure on the batteries.
Has anyone experienced this sudden power loss before or know of a way to correct this problem. Everything else on the Garmin GPS 12 works great.
  • samiller71 Feb 26, 2008
    I have learned that my batteries were simply loose in the battery compartment. How they became loose, I don't know. For years, the GPS worked fine.
    My solution, after trial and error, was to insert a piece of folded paper into the battery compartment against the batteries to act as a spacer. This paper spacer keeps the batteries from moving and maintained contact.
Use the paper, It worked for mine. I almost tossed it but now it's fine.
Posted on Mar 05, 2008
Stay clear of rechargeable NiCads as they supply to low voltage and you may experience cutouts ? Use good quality regular alkaline batteries. Check battery terminals in gps (both ends) for corrosion/rust and clean if necessary.
Posted on Feb 26, 2008
Charged garmin forerunner 110 with 12 volts for split seconds and won't turn on anymore?
Power supply damage is most likely and depending on cost of the unit itself may or may not be worth fixing---kind of like hooking a radio up backwards on a 12 volt system--damage is INSTANT and sometimes fatal.
Dec 04, 2012 | Garmin Forerunner 110 GPS Receiver
I have recently purchased the Garmin nuvi 765T and I have charged it and waited to use in the car but after a few seconds of turning it on, it turns itself off after showing the "Garmin" company...
Try to soft reset it by holding the power button for at least 20 seconds till it restarts.
If that doesn't help - try a master reset to factory defaults by holding the lower right corner during startup for at least 20 seconds. This will erase all user data and starts the Garmin in factory default.
If it restart I suggest updating the software to the latest version on Garmin.com
Jul 04, 2011 | Garmin nuvi 765T GPS Receiver
Screen seems OK but there is no way to interface as it does not respond to touch. Unit is 255w and about 2 years old.
The solution to this problem is for you to calibrate the screen. Before calibrating the screen, i will advice you reset the gps. To reset your device, hold down the power button for about 15 seconds, it will restart itself and power up fully, if the touch screen does not still work, then calibrating the screen will do the job for you. To calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Hold the upper left corner of the screen, then turn on the nuvi,
  3. Release the power key once the garmin screen appears,
  4. Continue to hold the upper left corner of the screen for 30 seconds till a white screen with 'touch dots' appears,
  5. Then follow the rest of the guide from there.
It might take a few tries before it works for you but you have to keep trying till you get it right. I am very certain that this will work for you.
Dec 31, 2010 | Garmin nuvi 255W GPS Receiver
Garmin 775T screen is frozen
If you hold the power button down for about 4 seconds or so, it should ask you if you want to power off. If the screen is still unresponsive, if you hold the power button down for 10 seconds, it will hard reset the device, powering it off with no screen input needed. At that point, I would check the firmware and make sure that it's up to date, as well as try to figure out how old the battery in the device is as well and consider replacing that as well.
Nov 09, 2017 | Garmin n?vi 775T Car GPS Receiver
GPS operation freeze up
Upgrading the system software of your GPSMAP 545s will most likely fix your freezing up problem.
I hope that helps.
May 31, 2009 | Garmin GPSMAP 545s GPS Receiver
My Garmin GPS 12 Turns Black On turning on.
Try turning the unit on and hold the left arrow button down for about 10 seconds.
Apr 01, 2009 | Garmin GPS 12 GPS Receiver
Garmin Nuvi 260W shuts off before it fully loads maps
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Mar 19, 2009 | Garmin nuvi 260W GPS Receiver
GPS GARMIN 340 turn it off by itself.
Does the unit comes on by itself once power is applied to the unit? If it doesn't come on by itself, then there is a problem with your power supply. The unit is designed to detect when an external power supply is applied and turn itself on. It is also designed design to detect if you unplug the unit from the external power supply. It will say "Lost external power, shutting down in 30 seconds". BTW are using Garmin cables?
Dec 25, 2007 | Garmin StreetPilot C330 GPS Receiver
Suddenly turning off
Your battery is dead. You'll need to return it to Garmin for repairs. Mine did the exact same thing. Functioned fine in the cradle - showed full battery - but shut off immediately upon removal. They know about the problem and shipped me a new unit for free.
Nov 28, 2007 | Garmin Edge 305HR GPS Receiver
Garmin GPS 12 GPS Receiver Logo
237 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
