Question about Brother HL-5240 Laser Printer
Toner light and Status light stays on
I have just replaced a new toner cartridge, admittedly it is a compatable, but when I put it in the toner light stays yellow and the status light stays red and it won't print.
When I first turned it on all the light flashed green as usual but then in made a screetching noise and the tone and status lights came on and stayed on.
Any ideas what the problem and solution is please
    Problem Solver:
  • 11 Answers
Well it may need to be completely reset or you could try seeing if it is jammed or stuck in some way
Posted on Sep 11, 2009
How do i reset toshiba estudio 181 printer if the replace toner light keeps staying lid even when i put a new toner
Is nothing to reset, you must verify if the toner sensor is not dirt with toner. Best regards,
Dec 06, 2014 | Toshiba OEM ESTUDIO181 18 CPM/PPM...
Scx 3200 samsung status light
If you refiil the toner cartridge ,now must be change the cartridge chip.The chip countered the total copy,not how many time you refill the toner.The original chip working 1500 copies,change one new chip to 1,5K or 3 k or moreK(K=1000 copies).
Mar 26, 2013 | Samsung CLP 300 Laser Printer
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
Toner light comes on and status light is red after replacing toner cartridge.
Oct 12, 2010 | Brother HL 5250DN Laser Printer
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Toner light stays on
Have you removed the tape?
Try OEM toner from the manufacturer.
Good Luck.
Feb 25, 2009 | Brother HL-2070N Laser Printer
Status red and amber Toner light
This problem you are getting is to replace the toner cartridge. Have you recently changed the drum unit as well. If so exchange it back to the other one.
After installing new toner or full toner cartridge and removing the yellow plastic cover press the go button this should start the printer on a cycle and add the toner. If this doesn't work then the toner sensor has malfunctioned and will need replacing. This will in turn out way the cost of a new machine.
Hope this helps and not too late for you.
Thanks Jason
Aug 09, 2008 | Brother HL-5240 Laser Printer
IBM infoprint 1312 toner and error light.
If both Lights are solid, it means that the top cover is still open and the toner is low. Please make sure the top cover is closed all the way. If the toner light is blinking and the errror light is solid, it means there is a toner cartridge error. Please try a new cartridge. If that solves the issue, then you should return the damaged one.
Mar 10, 2008 | IBM Infoprint 1312 Laser Printer
Out of toner........ but not really.....
Print a Supplies Status page to see the actual pages printed...
To print the Supplies Status page from the printer, on the printer control panel, select
Reports Menu, Supplies Status, and then Print Supplies Status page.
If the page count from the Supplies Status page indicates that the toner should not be in need of replacement then you have a bad cartridge. Actually, the cartridge is probably fine but the chip on the cartridge has got a problem. Return the cartridge to O.D. and get another one. Unfortunately, chips that don't work properly in not all that unusual so HP has a pretty easy return policy.
Hope this helps.
Mar 07, 2008 | HP Color LaserJet 2600n Printer
Brother HL-5240 Laser Printer Logo
878 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
