Question about Sony SDM-HS73P 17" LCD Monitor
Sony SDM HX73 LCD screen - pungent odor bugging me
When I inspect the monitor for an odor as I get close and look over the top of the monitor I detect a pungent odor coming out of the vent that has been bugging me for quite some time.  It's awful.  It has REALLY been hurting my eyes and nasal passages.  Any clue what the problem is?
  • Kelly6 Apr 08, 2008
    Thank you!  Thank you!   . .  for taking time to Reply.  It helps narrow my search for the problem + alleviating some fears.
  • 180 Answers
If the monitor is working well you need not worry. If any electrolytic capacitor burst out this type smell may come.
Posted on Apr 08, 2008
I have a SONY SDM-HS93 LCD monitor, Maybe Monitor receiverd an electric overstress, so the screen displayed but screen disappeared after few seconds. And if I turn it off & turn it on again, it turns...
Siny LCD Monitor is so expensive. <a href="http//www.wholesaleeshop.com.au/LCD-Monitor/index.php?keywords=philips">Philips LCD Monitor</a> is good!
Nov 02, 2010 | Sony SDM-HS93 19" LCD Monitor
Monitor picture comes on for only 1 second and then it is blank (black) Color bars appear to be OK (for that second) when running the Self-diagnosis function.
timothy henr, Do you understand how the new screw-in, curlie-Q, energy efficient, CFL light bulbs generate white light?? You will when you find out just what makes the WHITE fixya background on this web page you are looking at!!! Black screen of death can strike at any time!! Do a reply when finished with your research of repair video clips at YOUTUBE. Your search terms are: "lcd monitor disassembly" and "lcd monitor repair." That should get you started. Your unit could have a "switch-mode-power-supply" that detects a problem with itself or another circuit and goes into "full" or "partial" shutdown mode. You should be able to tell the difference if you shine a bright flashlight 1 inch from screen when it goes black!! Partial=still see win-desktop. Full shutdown=no see desktop!!! What wil you do??? Fix or just trade up for new display?? 12fixlouie
Oct 15, 2010 | Sony SDM-HX73 17" Flat Panel LCD Monitor
Monitor going to sleep
juanmgerman0, Connect SDM-X82 to known-good pc that has all sleep mode, power-save mode disabled. (turned-off) If unit still goes to black screen mode, then look at the "date of Manufacture" on rear of unit and let me know if you see "2002 -2004" as the year produced. Retrevo lists unit as "time to retire". Power supply may be going into shut-down mode having detected a problem with itself or the CCFL inverter circuit. 12fixlouie
Aug 19, 2010 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
Colors are off on various web pages--red links are blue--pictures and game screens are okay though --Windows XP Pro--TFT LCD Color Computer Display
install the drivers of display new if persist then insert AGP card in AGP slot of grade 8X because that is not problem inbuilt display card does not support games and movie
Mar 05, 2010 | Sony SDM-HX73 17" Flat Panel LCD Monitor
LCD screen SDM-HS75P has a message on the center displayed all times.It says INFORMATION MODEL:SDM-HS75P SER.NO:1022769 MANUFACTURED:2005-18 and it stays on top of windows all time. How can I take this...
Press once the Input button. The menu appears. Press the Input button again and hold it. Now this is reduced to the problem of blocking the Input button (holding it with something). (Not very technical but then again neither is the restart when the computer blocks :D) Cheers
Mar 04, 2010 | Sony (141857441) 15 in. Flat Panel LCD...
My Sony SDM-HS74P display does not stay on.
I have the same issue and wrote the monitor off for now after checking all cables (and a different computer). The logic circuitry and panel are sill ok as I can see a faint image with proper lighting and close inspection, but no backlight makes it useless.
Since there are 4 lamps (CCFLs) on this model, the problem likely is not there but on the inverter circuitry driving them. This does not look easy to replace as this is part of a bigger board.
It looks like some could repair by changing a few (or even one) component on the board, but unless your are used to this (de-soldering and soldering back), you are kind of stuck.
I will attempt this if I have time as I hate junking 99.9% ok hardware. In your case since this is an old monitor you should just replace it if not technically (on the electronics side) apt.
Dec 13, 2009 | Sony SDM-HS74P/S 17" LCD Monitor
Cant find vista driver for monitor Sony SDM-HX73
Go here and do some searching for a driver that will work. http://driverzone.com/device.php?id=54867 If you do not find one, then I suggest you contact Sony at> http://esupport.sony.com/US/perl/contact-land.pl?mdl=SDMHX73
Nov 28, 2009 | Sony SDM-HX73/B (Black) Monitor
Vertical line top to bottom rightside of screen
hardware problem. please call manufacturer for warranty service
Nov 03, 2008 | Sony SDM-HS53/HT 15" Flat Panel LCD...
same thing with my computer
Oct 04, 2007 | Sony SDM-HX73 17" Flat Panel LCD Monitor
Open Questions:
Sony SDM-HS73P 17" LCD Monitor Logo
119 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
