Question about Maxtor OneTouch II external hard drive 500GB 7,200 RPM - FireWire & USB (E04W500)
Maxtor external hard drive crashed. Help!
Maxtor external hard drive crashed. It is a NAS system, so it is a networked hard drive. I have my photos there. Anybody have advice? Help!
ImWireless
  • 113 Answers
SOURCE: maxtor external hard drive is not accessable
- Do you hear any beep sound when you plug in the USB drive into the laptop? - You can also try a different USB cable - Try connecting the hard drive to a different computer and see if it works All those steps will help you determine where the issue is. Please revert back with any other observations. Good Luck
Posted on Mar 30, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Maxtor External Hard drive not compatible with Mac
I would check Maxtors website to see if there is compatibility issue using that particular drive on a Mac.
Posted on Jun 10, 2008
SOURCE: power supply details for Maxtor 500 gb, external hard drive and ? manual
The PSU for my Maxtor 500Gb 9NZ2A4-500 drive is 12V DC, 2A rating, 2.1mm "plug" with centre "hole" as positive.
Regards, kbsguru
Posted on Nov 24, 2008
SOURCE: power supply for Maxtoe Basics External Hard Drive 500GB
Is 12VDC 2,0A the inner pin is + and the outer pin is -
Posted on Dec 04, 2008
SOURCE: Maxtor Basics 1Tb external hard drive not working
Apri il prompt dei comandi e digita cd.. e premi enter tante volte quante servono per andare in C:> ; ora digita CHKDSK X: \F dove X: dovrai sostituirlo con la lettera assegnata all'HD in cui non riesci ad entrare, premi enter. In poco tempo corregge gli errori, non si sa (almeno io) come si sono formati, e tornerai a riveder le stelle! Te lko auguro ame ha funzionato
Posted on Apr 28, 2009
Unable to download the Seagate Central NAS 1D driver on my Windows Vista desktop....help?
I think you mean hard drive. NAS devices aren't meant to be plugged into computers. They're meant for networks. NAS means "Network Attached Storage". There should be a disc that comes along with it to set it up. If you don't have one, you can connect to it through a web browser to set it up, thats usually how its done. If you look at the devices in your network, you should find its name, and then you can type in its name in a browser. As an example, if its name is seagate-nas, then you type "seagate-nas\" (without the quotes, and with the '\') into your browser and it should come up
Jan 12, 2015 | Seagate Central 3TB Personal Cloud Storage...
Lost password of the administrator how to reset password?
hi
go to following link you will find your hard drive solution
http://www.laptoptips.ca/security/hard-disk-password/
Oct 07, 2010 | Maxtor MaxAttach NAS 3000 (A0801AA) 80 GB...
Maxtor exter hdd 500 gb green light flashes but cant be detected
maxtor one touch 3 -500 does not detect on my macbook pro worked fine on my G5
Sep 11, 2009 | Maxtor MaxAttach NAS 3000 40 GB Network...
Problem open up my maxtor one touch 500gb to retieve photos
first, recover your files. You will need to use hard drive deleted photo recovery program like Asoftech Photo Recovery, you can follow this video to recover deleted photo
http://www.youtube.com/watch?v=sNxApz_PBW8
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 09, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Stored static ip address in nas server and cant
I have a similar problem. There is a reset pinhole switch just beneath where the Ethernet port is that if you push it is supposed to reset the drives name and switch it to DHCP. You can see this in the manual. Unfortunately, this hasn't worked for me and I'm working through another solution to see if I can find the IP it is attached to.
Apr 21, 2009 | Maxtor Shared Storage II 2TB Network...
NAS Drive by ADS Tech not recognized on network.
You can log into your router and find out what IP address has been assigned to your NAS unit.
Then start up Internet Explorer Or Firefox and go to the address http://xxx.xxx.xxx.xxx (replace with the IP address of the NAS unit).
That should get you in. Then you will have to set the workgroup and share parameters. Once you have it setup you can always map the NAS unit and use it as a external hard drive.
Dec 18, 2008 | Computers & Internet
How to correctly disconnect maxtor 500 gigabyte external hd
Hi, Normally the steps would be: 1. In your PC, in the System Tray, click on the "Safely Remove Hardware" and then on the "Safely Remove USB Mass Storage Device-Drive(?); 2. Unplug USB cable; 3. Power down external device. Hope this be of some help/idea. Good luck and kind regards.
Sep 17, 2007 | Maxtor OneTouch II external hard drive...
Computers & Internet Logo
71 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
