Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
Wrong color print out
When print mono, it print out yellow
    Problem Solver:
  • 11 Answers
Check printer catridge placement and then check that the ink is not that old
Posted on Sep 11, 2009
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
How do i get printing drivers for this machine
Dear
the driver may downloaded from the site on putting the model.
http://support.hp.com/us-en/drivers
Thanks.
Feb 15, 2015 | HP Deskjet 1510 Inkjet Multifunction...
My printer won't print its sending blank papers through.
The ink/toner is probably out. Do you have the correct drivers for the device also?
Dec 02, 2014 | Brother MFC-J470DW Inkjet Multifunction...
Why has my brother mcfj4510 stoped printing black & Yellow
Check if the capillary tubes from the ink cartridges to the print head has bubbles ?
Jul 31, 2014 | Brother MFC-J4510DW Inkjet Multifunction...
Yellow patch error
Not too sure what you mean about a yellow patch error.
Does this 'Yellow patch" have a splurge effect or is it more regular?
The only thing I can suggest is try several purges of the head.
The other possibility is, some torn media stuck deep inside the print unit further investigation would be necessary.
Good Luck.
Apr 10, 2014 | Xerox Corporation Phaser 6600/N Laser...
Will not print in color
You can find answers to your Xerox questions at www.xerox.com/support
If the machine will copy in color it should print in color.
After verifying that it will copy in color, verify your driver is capable of being switched from black and white to color. If there are no color settings then you have the wrong driver. The link above will take you to the support page where you can download new drivers.
Mar 26, 2013 | XEROX MULTIFUNCTIONS Xerox Phaser...
Brother DCP 195c print problam [black and yellow] punjabi
try to clean the print head 2-3 times,if the problem persist chage the print head
Feb 24, 2011 | Brother DCP 165C Compact Color Inkjet...
Brother MFC-420CN All-In-One
unplug maqchine from power. take all carts out. wait 5 minutes. connect machine to power. insert carts as demanded. give the right answer if machine asks if the carts are changed. machine will do some cleaning.
do you use generic ink? in that case you might have clogged the printhead with wrong ink. The ph cant be cleaned anymore.
nevertheless try this (carts should be nearly full!):
press menue then start mono (blue copy) then fourtimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4. Machine will display init_all. press start mono. machine will refill tubes and
ph with fresh ink and do some cleaning. after that press 7 then 6 then 3 and start mono. machine will do a powerpurge.
press zero then 9 to do a quality test print. If it cant do the job leave maintenance by pressing 9 then 9. do the test print manually by pressing ink etc.
If you still do not see any colors the ph is clogged and cant be fixed anymore. It has to be replaced.
Dec 03, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
80 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
