my seagate 400mb external hard drive will turn on but not mount. It sounds like something is loose inside, bouncing up and down. Is it possible something came loose and will not let it come up to speed.
there posible to loose.. try to change the board reader / sata or ide reader// then save all the data in another hard drive... if the problem from the plate imposible can retrieve the data... or bad sector...
External hard drives are quite prone to this but it can also affect internal too to a lesser degree
The clicking you hear is referred to as the "Click of Death" as far as hard drives are concerned. It may sound like a regular click or ping.
And I am afraid it is as it says.
It was probably knocked, dropped, or maybe just mis-handled.
These are hard drives and not flash drives.
As such should be treated with care
If it is truly dead and you MUST have the information from it then the only real alternative is to send it to a data recovery expert. These services are NOT cheap
It is possible that on external hard drives you may just be using the wrong USB lead try a sorter one preferably the one that came with it.
Another trick is to remove the drive from its enclosure and where a SUITABLE PC is available you can often connect it directly inside the PC.
If you are extremely lucky you might be able to salvage information but this is not always the case.
If it is the drive and it was in an enclosure you can always put a new one in there.
I have a lacie 750 gb external drive used for media storage. When using explorer to search the drive...
(More)
I have a lacie 750 gb external drive used for media storage. When using explorer to search the drive it freezes up, eventually becoming unrecognizable to the computer and becomes inaccessible until I turn it off and back on. If played directly from windows media it will work for a while but eventually becomes unresponsive again. I tried check the disc for problems under the properties tab, but it freezes too and says the disc cannot be checked while in use, even though all programs are closed.
My memory stick won't open from the my computer page. i says access denied. I have to pull it out...
(More)
My memory stick won't open from the my computer page. i says access denied. I have to pull it out and put it back in the drive again to open it.
hello. my name is said, i want your help like never before, my trekstor harddisk fall from my tv...
(More)
hello. my name is said, i want your help like never before, my trekstor harddisk fall from my tv board, and suddenly it does not work any more. i tried to off and on it many times but nothing helped. don't know what to do ! please help. abudinsaid@live.com
