Question about Canon PIXMA MX310 All-In-One Printer
Canon mx310 all in one
I down loaded the driver for my canon mx320 but I cnot scan from my computer
    President:
  • 987 Answers
First uninstall the driver then disconnect the USB cable ...reinstll the driver then re-connect the cable ...
Posted on Sep 11, 2009
I lost my cd to my canon MX320 and cannot scan or do any of the things I use to be able before my other pc broke.I now have a windows7 laptop and would like all the ammenities that my printer does on my...
Canon has the drivers and software for supported OS versions here: http://usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx320?selectedName=DriversAndSoftware . Select your OS in the drop-down menu. Make sure to select the x64 bit version if you have Win7 64-bit. To check this, click Start > Control Panel > System and Security > System. If the OS title ends with x64, you have the 64-bit OS. Otherwise it's the 32-bit version.
Expand the section marked software and get the MP Navigator to get the full feature set of the all-in-one. Download this file. Then disconnect data cable from the computer. Uninstall the generic driver that is currently installed. (Start > Control Panel > Devices and Printers ; right click on the MX320 and choose Remove Device) Reboot the computer if prompted to do so. Then find the MP Navigator software installer and double-left click on it. The UAC prompt will come up and you need to accept the changes (note you must be the system administrator). Then connect the USB cable when prompted to do so.
Unfortunately you will not be able to download any third-party software that came with the original CD.
I hope this helps.
Sep 13, 2011 | Canon PIXMA MX310 All-In-One Printer
My canon mx320 won't scan . it says pc standby then does nothing
I recommend that you install or reinstall the software for your unit.
Here is a link to it:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx320#DriversAndSoftware
Apr 29, 2011 | Canon PIXMA MX310 All-In-One Printer
I need a manual for my mx320 where can i get a copy
Hello
You can get the manual from Cannon MX320 form Here
http://software.canon-europe.com/products/0010697.asp
You can find the manual down list as user guide
Hope this helps, if so do rate the solution
Jan 03, 2011 | Canon PIXMA MX310 All-In-One Printer
Where is the ink on a cann pixma mx320 all in one printer
Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place. The FINE Cartridge Holder moves to the left. There's your cartridges, and this is also the procedure to replace them.
Dec 16, 2010 | Canon PIXMA MX310 All-In-One Printer
My canon pixma MX320 printer won't scan and when it attempts to it says there is no scanner detected
Hi!
Your printer will be detected as scanner if you successfully installed all feature of the drivers from the cd installer.
After installing the driver, the printer should be connected directly to the pc to detect the printer as scanner.
If the printer is on network... connect the usb to the pc that you are using.
Post back if you still have question.
Please rate thanks.
Nov 04, 2010 | Canon PIXMA MX310 All-In-One Printer
When trying to scan on my canon mx320 printer I r...
I just got done talking to Canon tech support about this issue. You have to have the MP Navigator software installed for that to work. Also, it could be that the Navigator software needs to be reinstalled because something is corrupted
May 21, 2010 | Canon PIXMA MX310 All-In-One Printer
How do I change the ink on my Canon MX320
Just open the top cover together with the scanner bed.
When the cartridge carrier move in the middle of the printer, that is the time you can replace the catridge. Lift up the top cover for the cartridge carrier and then the cartridges.
When replacing the cartridge. Push the cartridge down the carrier, you will hear a snapping sound. Return the top cover for the carrier and the scanner bed.
May 20, 2010 | Canon PIXMA MX310 All-In-One Printer
How do i down load the printer to the new computer with out the disk
download the driver for your printer from here http://drivers.softpedia.com/get/PRINTER/CANON/Canon-PIXMA-MX310-MP-Drivers-100.shtml after instal reboot and you can use your printer.
Dec 27, 2009 | Canon MX310 Office All-In-One Printer
Canon mx320 does not scan
make sure that scan driver is completely installed in your computer.
To scan a documents in jpeg format, use the scanner icon in the control panel of your system. Insert your document in scanner bed then double click the scanners & cameras icon in the Control Panel.
To scan a documents and save in pdf format. just press the Scan button in the printer and save the documents in your computer once the scan window appear.
Oct 20, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
172 people viewed this question
old marine
old marine
