Question about Frigidaire FEQ1442ES Electric Dryer
No heat , but machine function ok
Took top cover off see light come for a second or to and then turns off?
  • crowncres Sep 11, 2009
    this a gas dryer
  • 986 Answers
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 12, 2009
  • Roger Campbell
    Roger Campbell Sep 12, 2009
  • Roger Campbell
Reads "machine is rinsing open knob"
the internal motor is not running .so its not making noises as usual.
servicing required
Sep 18, 2008 | Starbucks Saeco Italia Digital Barista...
Where is the scanner lock switch on the mx850
You need to lift the document cover, and you should see a small gray slide type switch on the top of the printer's scanner, near the front left corner of the glass. Slide the switch to the unlock position, close the document cover, then turn off the machine. Wait 5 seconds, then turn the machine back on. This should restore the scanner function.
Dec 19, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
Jan 26, 2010 | Rancilio Silvia Espresso Machine
MNo Heat on Samsumg cloths dryer DV328AEW
Stat blown due to overheating/ check hose is venting out ok make sure all filters are very clean..if this is all ok should function well...!
Nov 05, 2009 | Coffee Makers & Espresso Machines
Magic Delux - Not heating
try to descale your machine to see if it helps.
Aug 24, 2008 | Saeco Magic De Luxe Espresso Machine
Scanner Lock Switch
Lift the document cover, and you should see a small gray slide type switch on the top of the scanner, near the front left corner of the glass. Slide the switch to the unlock position, close the document cover, turn off the machine. Wait five seconds, and turn machine back on. This should restore the scanner function.
Jul 16, 2008 | Canon PIXMA MP830 All-In-One InkJet...
No heat on tumble dry programme. Display flashed F 13.
You need to replace the heating element for the dryer which is positioned on top of the outer drum. Remove the top cover of the machine and locate the heater.
Nov 01, 2007 | Hotpoint Ultima WF860 Front Load Washer
Tricity Bendix WDR1240W Condenser dryer problem
Check the fan that is supposed to blow the hot air into the drum. It may be seized or jammed. It should be situated on the top of the outer drum. You will need to remove the top cover from the machine and identify the blower fan.
Nov 01, 2007 | Tricity Bendix WDR1240W Front Load Washer...
Washing light flashes on Frigidaire FDB1050REM dishwasher
1) Turn off the breaker to the machine.
2) Wait 30 seconds and then turn it back on.
3) All the lights will be flashing. At this point turn the dial to "rinse only" and then press "Heat dry" and "Start/Cancel" at the same time.
4) The Machine will go into maintenance mode going through all the cycles quickly.
5) After this is finished the problem should be solved.
Apr 05, 2007 | Frigidaire FDB1050REM Dishwasher
Frigidaire FEQ1442ES Electric Dryer Logo
87 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
