I HAVE A 65"MITSUBISHI DIAMOND SERIES REAR PROJECTION TV,2003 OR 2204.WORKING GOOD MOVED IT FROM ONE ROOM TO DOWN TO LIVEROOM.TTRIED TO TURNIT BACK ON AND THE GREEN LIGHT IS BLINKING ALL THE TIME,
You have the one that the capacitors go bad on, this set is the most complicated set to work on call the pro's but expect as heafty bill, the chassis has to be pulled out and sent into Mitsubishi for a rebuild.
That is called the "Parpadeo luz verde de la muerte" or Blinking green light of death. You may want to make sure all the wires are tight first and that when you moved it a cable wasn't seated. Instead of replacing the capacitors, your situation sounds more like bad solder connections on the DM module. Here is a link to a web forum where they talk about this exact problem.http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens.html Blinking Green Light of ***** frequent prob Mitsubishi rear proj...
IF model number posted is correct and green power light comes on for a few seconds and then goes off: On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
Try replaceing the DM capacitors that often cures that symptom. You can get the V26 DM repair kit from www.tvrepairworld.com the kit also contains the CD with detailed instructions.
Sounds like your TV is overheating. How dirty is the filter on the side? Is the fan on the back turning ok:? Does it look real dirty? Is so, a good cleaning is in order. Also, there is a fan under the lamp. Can you determine if it is working...the air flow may be obstructed (from the clogged filter) and it takes some additional time to cool.
I had the same problem. Unplugged it, reset it, everything. I went to work the next morning and left the light blinking, came home from work and it was off. I turned it on and so far, so good. Just give it some time to reset internally
