Question about Biostar iDEQ 210M Barebone
IDEQ will not turn on
Ive been asked to wipe the hdd of this machine only problem being i cant switch it on , orange light is displayed and cant turn the thing on atall any ideas as to why?
2 Suggested Answers
  • 283 Answers
SOURCE: power on doesn't show display
Yellow light means no video signal is being recieved,sound like a video board issue,good luck,(if you have on board video only way to fix is m/board replacement but if you have expansion slots avalible you can add video board.
Posted on Jan 08, 2011
My photocopier machine Konica Minolta, when I power it on, the lights turn on, but the display screen does not, on the start button, the yellow light appears.
Sounds like the LCD or main board has blown a fuse. Look for a small fuse. This may require the machine to be opened up. Contact Konica customer services as this is a common fault with the c250 range
kindregards
Mar 07, 2015 | Konica Minolta Bizhub C253 Copier
Help Black screen fan but no hdd light
No display and not booting after getting very hot is likely to be a GPU issue. This is repairable.
Jun 02, 2014 | HP Pavilion g7-1310us 17.3" Laptop
What graphics card can i use to fit ideq 220m model
You need an AGP graphics card. Preferably 8x. These are getting difficult to find now as the interface has been replaced (in general use) by the PCI-E standard. Hope this helps.
May 31, 2012 | Biostar iDEQ 220M (IDEQ220M) Barebone
Power on doesn't show display i power it off and a yellow light stays on , is this fixable , i have two of them with the same problem one is ideq 330p and the other one is a ideq 200n
Jan 08, 2011 | Biostar iDEQ 330P (IDEQ330P) Barebone
My canon IR 3300 copier trips as i swithc the machine
hOW DO YOU THINK TRIPS?
Is it "frozen" and you cant use display, or copy, or print, ...
If your copier has booting issues, you can try the HDD defrag function.
To execute HDD defragmentation, pres 2 and 9, hold it, and switch on the copier, hold the 2 and 9 until the display shows you litlle squares, wich means that defrag is in progress.
After a while when it stops turn on and off the copier.
If there is no squares beside first one, its no good.
You need to upgrade the system software, language, ...
Best solution and long term would be that you call service and then they replace HDD and upgraded software.
Mar 01, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Beko WMA 520 W. how do the wires sequence go on the on/off switch.....2 grey, 2 orange. cant remember
You can try calling this number and ask them
0870 241 0357 (UK Washer Service)
Or Go to this page and send an inquiry
http://www.beko.co.uk/partsandaccessories.aspx
I don't want to shoot from the hip here but I would think orange to orange on ONE set of contacts and grey to grey on the other.
You can use an Ohm meter to read the switch across the terminals to see which 2 contacts open or close on ONE side of the switch then connect grey to grey leaving the remaining two (2) terminals the obious connection for orange to orange.
Jan 20, 2010 | Washing Machines
Ideq evesham motherboard
Visit the motherboard website in the internet and look there for the video driver for your motherboard. You can find it the download section of the site.
Nov 29, 2009 | Biostar iDEQ N1 Socket754/GeForce...
X box console making clicking sound at start up, doesn't wrk
if this thing happens then that means your hdd is already corrupted.buy new hdd and replace it.that solves the problem
Dec 17, 2008 | Microsoft Xbox Console
Error code 4 flashing orange - code 5c00
Hi Chris,
Error code 5c00 (flash in orange /green 4 times) indicates that purge unit has broken so that the printhead is locked down when initializing process performed. Sorry I have to say that no first aid for this problem unless you bring it to nearest service centre for part replacement. Hope this information helpful for you.
Regards,
Source:
Canon Inkjet Forum
Dec 13, 2008 | Canon PIXMA iP90 Mobile Printer
Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
si
Nov 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Biostar iDEQ 210M Barebone Logo
88 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
